Unable to connect to specific web-site
FIXED- Subscribe to RSS Feed
- Unable to connect to specific web-site
- « Previous
- 1
- 2
- Next »
Re: Unable to connect to specific web-site
4 weeks ago
Hi, I am using the Plusnet firewall - set to 'Low'.
If the fixed IP address can be changed, I'd hope that would resolve the problem given that I've tried the same laptop on a different network / router.
4 weeks ago - last edited 4 weeks ago
@Jodel thats why you've got a static IP. Is there a reason why you need the Plusnet firewall ?
If not ,the turn the firewall off and then drop and reconnect he PPPoE iession ( or turn the router off and on )
You should now get a different dynamic ip
4 weeks ago
MisterW, I didn't consciously activate the Plusnet firewall (I don't believe) I think I just set everything up with default settings. I'll try what you suggest and will report back.
4 weeks ago
@Jodel if it doesn't fix it let me know and I will get it raised up for you.
4 weeks ago
Hi willcutforth - I've just tried resetting the router via the hub manager page and also tried switching it off / on with no joy. My IP address hasn't changed unfortunately. If there is something you can do at the Plusnet end, that would be great
4 weeks ago
@Jodel did you turn the firewall off first in your account ?
4 weeks ago
Hi MisterW - yes, I turned off the firewall first, logged in / out to make sure the setting had been saved.
4 weeks ago
In that case you'd better let Will know.
Disabling the firewall should have reverted to a dynamic IP once the connection is 'bounced'.
4 weeks ago
https://iplocation.io/ aggregates multiple iplocation awareness services.
4 weeks ago
@Jodel I have raised a ticket here:
https://www.plus.net/wizard/?p=view_question&id=241539706
Just need you to reply
4 weeks ago
Hi Will, thanks - I've replied to the ticket. If you need any more information, let me know.
- « Previous
- 1
- 2
- Next »
