Turn a extension socket into a master socket.
- Re: Turn a extension socket into a master socket.
25-02-2013 5:55 PM
Can you turn an extension socket into a master socket? I am a very experienced installer but can't find anywhere on the net on how to do this? I can't use the extension socket due to being on fibre. I don't mind getting into trouble by BT or BTOPENREACH. My Master socket looks like this and my extension socket looks like this Is there anyway changing the ext (extension) socket into a master socket?
Any Help will be appreciated
J
25-02-2013 6:05 PM
You could have asked for it to have been moved when you had it installed but having failed to so that you are stuck with it unless you do something totally illegal
25-02-2013 6:09 PM
J
25-02-2013 6:25 PM
Quote from: JamieDanjoux I can't use the extension socket due to being on fibre.
What are you actually trying to achieve and why?
25-02-2013 6:31 PM
J
25-02-2013 6:33 PM
25-02-2013 6:43 PM
25-02-2013 6:46 PM
25-02-2013 6:53 PM
25-02-2013 7:08 PM
adie:quote
25-02-2013 8:49 PM
PN are a wholey owned subsidary of BT and I'm sure they would be reluctant to see a post here apparently breaking the T&C that BT have set. BT are the sole installers of fibre and PN could not be seen to assisting someone to break those T&C's!
York.
25-02-2013 8:57 PM
25-02-2013 9:16 PM
Quote from: JamieDanjoux Hi everyone,
J
Really!!!
25-02-2013 9:21 PM
I was also intrigued as to why the master socket in the photo looks like it is screwed to some sheet asbestos
25-02-2013 9:27 PM
*30FTTC06. I'm an electrician not some fancy telephone engineer, but I do have experience installing cables etc...
