Sync, Profile etc - is my understanding correct?
- Sync, Profile etc - is my understanding correct?
- « Previous
- 1
- 2
- Next »
Re: Sync, Profile etc - is my understanding correct?
05-02-2012 6:39 PM
spraxyt - I've not had any problems with any type of noise on the line that I can remember.
I had a go at swapping to a different router yesterday but it was just the same.
However, the stats (to me) don't seem as horrendous now even though I'm back on the original router:
Uptime: 1 day, 10:27:18
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 796 / 5,488
Bandwidth (Up/Down) [kbps/kbps]: 440 / 3,072
Data Transferred (Sent/Received) [MB/GB]: 290.13 / 2.67
Output Power (Up/Down) [dBm]: 12.5 / 17.5
Line Attenuation (Up/Down) [dB]: 26.5 / 45.0
SN Margin (Up/Down) [dB]: 18.5 / 8.0
Loss of Link (Remote): 0
FEC Errors (Up/Down): 268 / 994,169
CRC Errors (Up/Down): 35 / 10
HEC Errors (Up/Down): 10 / 22
Message 16 of 22
(422 Views)
06-02-2012 1:23 AM
Yes, the new stats do look healthier, particularly the downstream SN Margin. Starting the router from cold has probably helped to reinitialise all the counters properly. Previously the HEC error values would have been negative and positive counters might not have started at zero.
The router must have been disconnected when you tried the spare and it's always possible that unplugging and reinserting cables has cleaned or remade a slightly suspect contact.
David
Message 17 of 22
(422 Views)
06-02-2012 7:18 PM
Just to finish this one off.
As anticipated my connection had been banded. This has now been sorted out and and I'm now connected at 5752 kbps and getting speed test results just under 5Mbps.
Needless to say I'm now happy once again.
Thanks everyone for your assistance.
Message 18 of 22
(422 Views)
06-02-2012 7:46 PM
Glad to hear that the problem has been fixed. I'd appreciate your stats being posted for future guidance. ![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
David
David
David
Message 19 of 22
(422 Views)
06-02-2012 8:50 PM
As requested - interestingly the errors seem to be mounting up fairly quickly again. Should I be worried or is it just something to keep an eye on?
Link Information
Uptime: 0 days, 4:38:40
Maximum Bandwidth (Up/Down) [kbps/kbps]: 800 / 5,960
Bandwidth (Up/Down) [kbps/kbps]: 440 / 5,752
Data Transferred (Sent/Received) [MB/MB]: 17.15 / 82.27
Output Power (Up/Down) [dBm]: 12.5 / 19.5
SN Margin (Up/Down) [dB]: 19.0 / 5.5
Loss of Signal (Local/Remote): 131,074 / 0
Error Seconds (Local/Remote): 131,075 / 0
FEC Errors (Up/Down): 72,579 / 4,179,903
CRC Errors (Up/Down): 2,533 / 33
HEC Errors (Up/Down): 4 / 210
Link Information
Message 20 of 22
(422 Views)
07-02-2012 1:41 AM
Thanks. Difficult to be explicit but I just have the feeling that things are not as good as they should be. Downstream sync speed is about 1000kbps on the low side but most noticeable is the upstream CRC error count looks to be excessive, My stats show 2562 upstream CRC errors after 23 days whereas yours show that number in 4 hours. Something to keep a watch on I guess.
Unless you get problems with low speeds or disconnections it would probably be difficult to get further testing done, though you could query the high upstream CRC error count. The mean time between upstream errors is about 6 seconds (4h 38m 40s is 16720 seconds divided by 2533 = 6.6 seconds). I think one every 30 seconds would be regarded as satisfactory.
I'd be inclined to see what the number looks like after 24 hours.
David
David
David
Message 21 of 22
(422 Views)
07-02-2012 11:54 AM
Quote from: ciderboy As requested - interestingly the errors seem to be mounting up fairly quickly again. Should I be worried or is it just something to keep an eye on?
If you have a Thomson router, make sure the latest firmware has been installed.
Message 22 of 22
(422 Views)
- « Previous
- 1
- 2
- Next »
