Thomson v8 router login probes
- Thomson v8 router login probes
02-02-2012 5:39 PM
Im having a mare trying to login to my router I'm doing admin upper lower both upper and lower at start also entering my serial number ad I still can't log in , I set my pc to remember the password and this also won't log in , what option is it with resetting my router and losing all the setup and ip allocations
Message 1 of 6
(7,513 Views)
5 REPLIES 5
Re: Thomson v8 router login probes
02-02-2012 6:26 PM
I believe it's the 0 (noughts) and the O (letter o's) that catch you out.
Message 2 of 6
(533 Views)
02-02-2012 7:17 PM
The router logon name should be admin (all lower case letters) and the password the serial number of the router (CP... all letters uppercase). With the serial number, 0 and 8 are sometimes confused as 0 has a stroke through it to distinguish from letter O. The digit 0 has straight sides, whereas 8 has pinched sides.
If you do want to reset the router to factory defaults that is done by holding in the pinhole reset button on the back for 10 seconds (until the power LED turns red) then allow the router to re-sync (and set itself up again) normally.
David
David
David
Message 3 of 6
(533 Views)
02-02-2012 9:52 PM
Thanks typically my serial number hasn't got o or 0 or 8 grrrrrrrr looks like I will have to do a master reset
Message 4 of 6
(533 Views)
02-02-2012 11:21 PM
Sorry for asking what could be a silly question, but ...
My answer was based on the assumption that your router was a TG585v8 (as stated in the title). The login name and password could be different if it was a v7.
David
David
David
Message 5 of 6
(533 Views)
07-02-2012 9:41 AM
I believe it's the same on the v7's - admin for the username and the serial number for the password, unless it's been changed.
Message 6 of 6
(533 Views)
