Slow speed - nearer exchange?
- Slow speed - nearer exchange?
Re: Slow speed - nearer exchange?
04-09-2010 4:01 PM
You could even attach a photo of the internals to your post
04-09-2010 4:04 PM
Quote from: Oldjim Does your socket have a BT logo on it.
No logo on it. Exactly as the picture here http://www.telephonesuk.co.uk/images/LJU2_front.jpg
04-09-2010 4:05 PM
04-09-2010 4:21 PM
04-09-2010 4:32 PM
1. Not standard telephone cabling that I'm familiar with and the wired incorrectly, normal installation have the blue, blue/white wires on terminals 2 and 5.
2. The incoming cable only need 2 wires to be terminated. Are you sure that one of the cables is the incoming cable?
04-09-2010 4:43 PM
04-09-2010 4:49 PM
04-09-2010 4:54 PM
04-09-2010 5:05 PM
04-09-2010 10:19 PM
05-09-2010 9:24 AM
05-09-2010 5:27 PM
Quote from: itsme Okay. Let assume that there is only 1 cable coming into the house, which is the one leaving the trunking at the bottom and this cable is going to the socket which you believe is the master. One tip to improve speed is to remove the ring wire. In you case it will be the 2 blue wires going to terminal 3. You can read about it here http://www.kitz.co.uk/adsl/socket.htm
Would I need to remove the ring wire on just the master socket, or on all sockets?
05-09-2010 5:29 PM
05-09-2010 5:41 PM
Have you asked your neighbours about their master socket, and where they plug in their broadband
05-09-2010 7:33 PM
Uptime: 0 days, 0:56:23
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,560
Output Power (Up/Down) [dBm]: 11.5 / 16.5
Line Attenuation (Up/Down) [dB]: 31.5 / 58.0
SN Margin (Up/Down) [dB]: 16.0 / 6.5
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 5,251
CRC Errors (Up/Down): 0 / 8
HEC Errors (Up/Down): 0 / 6
