Router set up daft question ?
- Re: Router set up daft question ?
16-06-2012 8:40 PM
hi all,
i have repaired my friends pc after lightning killed the mobo and router.
i have bought an N150 DGN1000 in pc world, shop price £50, reserve in the shop via iphone and collect, £32, anyhoo, and i have the pc and router at my house.
if i set up the router at my house with their connection settings, can i plug it into my phone line to test, or will it get confused.
we both use plusnet ,but different packages
or am i being fick
any help much appreciated
or am i being fick
Message 1 of 6
(1,098 Views)
5 REPLIES 5
16-06-2012 9:38 PM
I *think* you'll be okay as long as you disconnect your kit and plug theirs in.
Message 2 of 6
(553 Views)
16-06-2012 10:08 PM
thanks for the reply, thats what i was thinking but wasnt sure if it would confuse my BB, in the old days you could connect your dial up from any phone line............. but then petrol was the same price per gallon as it is now per litre
Message 3 of 6
(553 Views)
16-06-2012 10:30 PM
Providing you are both with Plusnet otherwise it won't connect all the way
Message 4 of 6
(553 Views)
17-06-2012 1:34 AM
thanks Oldjim, i thought you would be along soon, i'll give it a whirl in the morning, Jelv cant be far away
cheers guys
cheers guys
Message 5 of 6
(553 Views)
17-06-2012 11:01 AM
worked a treat, thanks again
Message 6 of 6
(553 Views)
