No dial tone & waiting for the OR engineer to turn up
ScottJames
Hey everyone
My plusnet service is due to go live today. I am currently waiting for an Openreach engineer to turn up to enable fibre, and I have just checked our telephone and there is no dial tone. Just wondered if this is normal? Our line rental is being switched to PN as well.
15 REPLIES 15
jelv
Fixes: 10
Re: No dial tone & waiting for the OR engineer to turn up
Quote from: ScottJames
Sounds promising - it has to be physically rewired in the cabinet.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
ScottJames
Yeah you were right jelv! Just got a dual tone back and the engineer has just called to say that he is on the way. Hopefully it will all go smoothly!
adamwalker
Fixes: 221
Just checked and glad to see the line and broadband are now up and running.
 Adam Walker
ScottJames
Hi Adam
Yep all up and running Smiley Have a slight issue though where the router is synced at 78 down, and the most I can get in a speed test is 36. So I wondered if my connection has been capped?
jelv
Fixes: 10
Is that using a wired connection to the router?
ScottJames
Hi jelv
I have tried wired and wireless.
jelv
Fixes: 10
What does https://portal.plus.net/my.html?action=data_transfer_speed say for your current line speed?
jelv
Fixes: 10
Does this look similar http://community.plus.net/forum/index.php/topic,122173 ?
Could someone from Plusnet check ScottJames' account please.
Chris
Legend
Fixes: 169
Already been done and fixed: http://community.plus.net/forum/index.php/topic,122173.msg1059195.html#msg1059195
ScottJames
Thanks for the help jelv & Chris. Just had a look in my member section and it is now saying current line speed 78Mb  Cheesy Can't wait to get home and try it out!
art15t
Hey everyone
This sounds very familiar ....ho-hum  Shocked
http://community.plus.net/forum/index.php/topic,122190.msg1059245.html#msg1059245
ScottJames
Hey art15t
I have just replied in your thread  Smiley
ScottJames
Hey Adam & Chris
Just got home and done a speed test, and it is much better as you can see in the signature  Cheesy Do you think the line speed will change over the coming days?
Thanks again for sorting this out.
Edit: had to remove the image as it was too big. But I am getting about 69 down and almost 18 up  Smiley
picbits
It may vary, it may stay the same. FTTC is a strange beastie.
Mine started off at around 73Mb and has bounced between 73Mb and 65Mb over the past year. Still more than enough bandwidth for just about anything I throw at it Smiley
