Just been connected and think my profile is wrong?
- Just been connected and think my profile is wrong?
07-01-2014 6:49 PM
Hey everyone
Just been connected and did a speed test which is coming out at 35Mb. My guideline was 79-80 down, and I have just looked at the router stats and it is saying that it is connected at 78.12 down and 19.53 up.
If a member of staff at plusnet could take a look at that it would be great
Message 1 of 7
(1,297 Views)
6 REPLIES 6
Re: Just been connected and think my profile is wrong?
07-01-2014 7:03 PM
If you are connected at 78/19 then your profile is probably correct.
That speed of 35Mb sounds like you might have been using a wireless connection. If you were then you should try again with an ethernet connection.
Message 2 of 7
(644 Views)
07-01-2014 7:22 PM
Hey gofaster
That was over a wired connection. I thought that I had read on here that people have been put on the wrong profile so it is only allowing up to 40Mb, even though their connection was synced faster?
Message 3 of 7
(644 Views)
07-01-2014 9:11 PM
What speed are you getting on the upload?
Message 4 of 7
(644 Views)
07-01-2014 9:43 PM
Hi Chris
Upload speed is 18.55 on my last test.
Message 5 of 7
(644 Views)
08-01-2014 10:09 AM
Message 6 of 7
(644 Views)
08-01-2014 10:27 AM
No problem at all Adam Just nice that there is a place that we can come when there is a problem, and someone sorts it out quickly.
I am at work at the moment, so I will test it when I get home. Will I have to turn the router off and on again?
Thanks for your help with this.
Message 7 of 7
(644 Views)
