Speeds?
Warrinja
Speeds?
I've been rather concerned about my speeds for quite some time, but only recently decided to look into it, I've done several speed tests using speedtest.net and have tried it with a few different fairly local servers, my DL speed is 7.59mbps whilst my Up speed caps out at around 0.37mbps, I get really slow Steam download speeds and was wondering if these speeds are consistent with what I should be getting on my Line?
9 REPLIES 9
Oldjim
Resting Legend
Fixes: 63
Re: Speeds?
The upload needs to be uncapped - there is no charge for this
To get a clearer picture please provide the information requested here http://community.plus.net/forum/index.php/topic,96155.0.html
Pettitto
Fixes: 5
Re: Speeds?
Uncapping the upload won't benefit your Steam downloads though.
I'd be happy to take a look at your downstream speeds when I'm back in the office on Monday for you.
Warrinja
Re: Speeds?
Uncapping my upload would be handy but yes if you could check my downstream when you get a chance that'd be much appreciated, thanks Smiley
jelv
Fixes: 10
Re: Speeds?
If you post the information Jim has asked for we can tell you if the speeds your are seeing are appropriate for your line, if there are any obvious problems with the way the line is configured and possible ways the speed could be improved.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Warrinja
Re: Speeds?
Link Information
Uptime: 15 days, 5:56:19
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,148 / 9,652
Bandwidth (Up/Down) [kbps/kbps]: 444 / 9,080
Data Transferred (Sent/Received) [GB/GB]: 11.13 / 177.54
Output Power (Up/Down) [dBm]: 12.0 / 20.0
Line Attenuation (Up/Down) [dB]: 22.5 / 37.0
SN Margin (Up/Down) [dB]: 27.0 / 3.0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1,729 / 0
FEC Errors (Up/Down): 6,534,944 / 267,817,390
CRC Errors (Up/Down): 5,164 / 335,422
HEC Errors (Up/Down): 324 / 6,930,584
BT Wholesale results:
Download speed (Mbps) 8.18
Upload Speed (Mbps) 0.33
Ping Latency (ms) 41.63
And lastly: Theres no Estimated line speed being held on account apparently
and Current Line Speed shows as 8Mb
adamwalker
Fixes: 221
Re: Speeds?
I've just checked the account and the speed profile was mis-matched, that can in turn mean we're not managing the traffic on your connection correctly and could cause issues with specific types of traffic such as downloads.
I've corrected that so please let us know if there's still a problem.
Adam
 Adam Walker
Warrinja
Re: Speeds?
Will it be worth me restarting the router for any of these changes to take effect at all?
Pettitto
Fixes: 5
Re: Speeds?
It might be worth logging into your router and pressing the 'Disconnect' button and then reconnecting by pressing the 'Connect' button.
Warrinja
Re: Speeds?
Not sure quite what was done to my line, but I seem to be getting the worst connection I've had, constant Skype disconnects and my ping while playing Dota2 keeps rocketing and then getting disconnected.
