Mid Afternoon Dropouts
- Mid Afternoon Dropouts
Re: Mid Afternoon Dropouts
29-09-2014 4:27 PM
It looks like the US has been capped, probably when the interleaving was switched on. Would this be an intentional action or an oversight to set the (by default capped) US correctly?
We are aware of capping slipping in on manual provisions, this might be another source of uncapped lines unintentionally becoming capped.
Kevin
29-09-2014 8:15 PM
engineer due thurs afternoon - starting to empty bookcase!
29-09-2014 9:25 PM
It is a good start. What happened at 19:10?
Which bits have yo not been able to follow? Right click this graph in RouterStats and tick overlay Rx synch please.
Note RS can sleep on the job - that zero line is likely to be lost messages (known bug) and can happen several times a day or never in a month. If you look at the SUMMARY tab you will most likely seen tone bins data. Just click the black stop button followed by the green start button.
I set up an alarm to sound is synch falls to zero. Helps to cover the false disconnects.
Kevi
29-09-2014 9:36 PM
I have been having big problems keeping my PC connected to the router since the f/w upgrade. The connection keeps grinding to a halt. It isn't the internet connection as other devices seem fine and the router status doesn't look untoward. I am updating the wirelsss driver in case thats an issue and will try again.
Have already got Rx sync overlaid after I saw your examples
I do keep getting the drop to zero with no associated problems showing in the router so will try stop/start and set an alarm
30-09-2014 8:25 AM
30-09-2014 8:31 AM
had already done that due to previous experiences with these routers and connectivity issues. I still can't say I'm happy with it. Slow connections to some wireless devices and won't even give an IP address to my PVR so it won't act as a renderer to play the kids films which is not going down well. I will be glad to replace it but as long as it is performing useful diagnostic functions I will put up with it. Anyway, that's an aside, priority is to sort ADSL line and thanks for continuing to help with this.
Routerstats running ok this morning so far.
Jon
30-09-2014 8:40 AM
An aside - PVR - have you looked at the router's client list?
I have seen issues like this with a Vista PC. In circumstances I do not have a clear profile on it tries to get an IP address and fails to do so. However, when I check the router's DHCP client list the device is listed with a new lease / IP address. It is as though the allocation was not successfully set to / received by the client. Bouncing the router cures the problem!
Would be interesting to know if you see the same.
30-09-2014 8:52 AM
30-09-2014 9:47 AM
30-09-2014 10:30 AM
got really frustrated with performance on main desktop so factory reset router and stopped routerstats. However, attached is a couple of hours this morning that looks good to me. The two drops were routerstats misbehaving as the connection remained up.
30-09-2014 10:34 AM
Router non-responsiveness - what do the FEC counts look like? I gave seen TG routers disappear into a world if their own in the face of high FEC counts. When is BTOR coming?
30-09-2014 10:39 AM
Uptime: 0 days, 0:19:21
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 446 / 11,841
Data Transferred (Sent/Received) [MB/MB]: 3.61 / 25.79
Output Power (Up/Down) [dBm]: 12.6 / 0.0
Line Attenuation (Up/Down) [dB]: 17.1 / 29.5
SN Margin (Up/Down) [dB]: 31.3 / 6.1
Loss of Link (Remote): -
FEC Errors (Up/Down): 0 / 674
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Desktop is behaving so far post router reset. Wirelessly connected using the Intel AC card to referred to in other thread.
I presume running routerstats does not impact on a PC's overall connection?
30-09-2014 10:41 AM
30-09-2014 10:51 AM
I run RS all of the time on my main laptop (do not have a traditional PC) and normally do not notice any issues. RS can be a bit resource hungry so depending in the PC's spec...
Have a look at task manager.
Kevin
30-09-2014 10:57 AM
