Mid Afternoon Dropouts
- Mid Afternoon Dropouts
Re: Mid Afternoon Dropouts
30-09-2014 12:20 PM
It won't let the chromecast connect either
I am not going to spend any more time on it until the line is fixed and I can stick another router on the network!
30-09-2014 7:54 PM
01-10-2014 8:03 AM
01-10-2014 11:35 AM
One probable indicator that RS is up no good is that the synch speed either side of an event is the same. I think there is low level REIN here, there is some fall off of SNRM from 18:00 which (at this time of year) is too early for AM interference, which is what you are seeing later on.
It is a watching game now whilst you unpack that book case. Does the wire to the master socket come directly through the wall into the back of it or run from the left or right to its place behind the book case?
If the latter and the engineer decides to replace the socket, you might be able to get him to move the master socket so that it is no longer behind the book case. Would need a junction box and a short length of wire to reconnect your internal extension. Tea and chocolate hobnobs might help!
Kevin
01-10-2014 11:46 AM
as far as I am aware the socket is directly in front of of where the wire enters the house. Although I do remember a bit of a kerfuffle when the house was built in that plasterboard had been put up without making a note of where the phone line came in and they ended up having to knock several holes into the wall to locate it!
It has been rock solid at 6.1 for the last 2hrs with and almost straight line graph - apart from another RS drop.
I am ready for the engineer with a supply of hobnobs and look forward to hearing what he has to say. In some ways I hope he finds something as I am not keen to have interleaving on in the long term and I am reluctant to move to fibre until the issues are sorted. Do you think the low level REIN we might be seeing could have been responsible for the massive issues before interleaving was turned on?
Jon
01-10-2014 3:54 PM
It is possible. The SNRM shift is not much, looking back I suspect that it lifted around 22:00 so it could be TV related. Such patterns can be difficult to discern when there are other background things (continental AM interference) going on at the same time.
We watches, we'll see!
Kevin
02-10-2014 8:21 AM
02-10-2014 9:14 AM
Uptime: 1 day, 22:56:58
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 446 / 11,841
Data Transferred (Sent/Received) [MB/GB]: 212.04 / 2.15
Output Power (Up/Down) [dBm]: 12.6 / 0.0
Line Attenuation (Up/Down) [dB]: 17.1 / 29.5
SN Margin (Up/Down) [dB]: 31.2 / 6.1
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1,138 / 0
FEC Errors (Up/Down): 202 / 511,948
CRC Errors (Up/Down): 0 / 1,618
HEC Errors (Up/Down): 0 / 23,989
02-10-2014 9:48 AM
Interestingly, with the updated TG582n in the master socket you've had nearly 2 days uninterrupted connection. How does that compare with recent experience?
Kevin
02-10-2014 10:07 AM
I will wait to see what the engineer says and then migrate the router to the office via the bedroom extension socket to see if there are any issues with the internal wiring.
02-10-2014 3:41 PM
Uptime: 0 days, 0:06:35
Bandwidth (Up/Down) [kbps/kbps]: 446 / 14,074
Data Transferred (Sent/Received) [kB/kB]: 443.19 / 688.84
SN Margin (Up/Down) [dB]: 29.0 / 6.0
FEC Errors (Up/Down): 0 / 59
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
02-10-2014 3:50 PM
Well good news all round, especially as the line test did not report a fault.
Synch speed is markedly improved, but not quite as much as I was hoping for. On a good day, that line should synch at 16Mbps if the reported attenuation can be trusted.
I'll leave you to get things put back in line with your work permits and look forward to hearing how things are when you have the TP back upstairs.
Cheers,
Kevin
02-10-2014 4:05 PM
Upstream Downstream
Current Rate (Kbps) 444 15600
Max Rate (Kbps) 864 15836
SNR Margin (dB) 25.9 6.2
Line Attenuation (dB) 15.8 31.5
Errors (Pkts) 0 0
02-10-2014 4:29 PM
MUCH better! Synch is now 2Mbps higher than it was at the start of all this. Interesting that the TP reports a higher line attenuation. Difficult to know if that is the router or the upstairs location.
All you need now is interleaving turned off again and the US synch uncapping.
Now you can wait and see if the afternoon disconnects have gone.
Kevin
02-10-2014 4:33 PM
