It's Happening Again!
- Re: It's Happening Again!
02-01-2012 9:42 AM
I will try raising another fault but I don't have much hope.
![Sad Sad](/html/@5863905B9AC6EE4F2B28C1A2965ABC0C/images/emoticons/sad.gif)
02-01-2012 10:57 AM
You were using a Bipac 7800N weren't you? Does it still happen with that router? It has a much higher blip tolerance than most.
02-01-2012 11:06 AM
Quote from: nozzer If it happens at a regular time every day it's almost certainly something causing a blip on the signal, like a streetlight, or something in the house. Have you considered everything that switches on automatically in the house (immersion heater for example)?
I have been doing a bit of research and there is nothing turning on at 5:30 PM that effects the broadband.
Quote from: nozzer You were using a Bipac 7800N weren't you? Does it still happen with that router? It has a much higher blip tolerance than most.
It was better with the 7800N for a while but it is disconnecting again. If you could let me know the exact settings you use, I could give it another go.
02-01-2012 11:25 AM
Exact settings?? For the router? It's just plug and go!
02-01-2012 11:27 AM
Quote from: nozzer When you say "that effects the broadband" how do you know that? Or are you saying that there's nothing turning on or off at 5.30pm?
There is nothing in my house that switches on or off at 5:30PM. I live in a village with no street lights and I am not near any radio stations but I do live in the South so I suppose signals could be being picked up from foreign stations.
02-01-2012 11:30 AM
02-01-2012 11:45 AM
Try the Billion again and just leave it to its own devices. The SNRM "should" reset in due course.
02-01-2012 11:48 AM
Did you try leaving it at the lower sync rate and see if it holds
02-01-2012 12:07 PM
Stats:
ADSL Link Downstream Upstream
Connection Speed 5120 kbps 448 kbps
Line Attenuation 41.0 db 25.0 db
Noise Margin 9.9 db 23.0 db
02-01-2012 12:19 PM
This is specially the case with ADSL2 as I have seen it bounce the default noise margin from 9dB to 15dB in one go without any apparent justification
02-01-2012 12:24 PM
![Cheesy Cheesy](/html/@69488338D0B3891CC5F8AEAEEB30C648/images/emoticons/cheesy.gif)
02-01-2012 1:18 PM
Quote from: Oldjim I suggest you try not fiddling any more
I haven't really been fiddling, I am just been trying a few different routers. I won't touch it and I'll post a RouterStats graph as it starts to get dark.
02-01-2012 1:30 PM
02-01-2012 1:47 PM
Quote from: Oldjim Be interesting to see how it compares with this
What router is that?
02-01-2012 1:54 PM
