CSC Agents not answering the right question
- CSC Agents not answering the right question
22-11-2011 11:03 PM
3Mb FTTC
Re: CSC Agents not answering the right question
23-11-2011 7:51 AM
3Mb FTTC
23-11-2011 8:28 AM
Your sync rate is currently 2560, so that would give a profile of 2000 once it's had a period of stability. A couple of drops yesterday caused it to drop a little. I'm presuming you are currently using the test socket?
Jojo
23-11-2011 9:11 AM
And sorry, Yes I have reset the router to get back to the higher sync rate of 2560, so Yes maybe if I am lucky I will get back to 2Mb.
However, this is *also* overlooking the issue that the line is more unstable after the line was repaired, hence the 'couple of drops' are exactly what I am refering to as a problem, before the line fault, the line was much more stable.
3Mb FTTC
23-11-2011 9:24 AM
This is a plot of SNR taken at 15s intervals, so there could be more noise between those 15s intervals which we do not see. The variation of 1dB between 10-11dB is not an issue, such variations are how this line looked for many years, it is the larger variations down to 7dB for example which indicate the line is now sensitive or susceptable to noise. Those spikes were not frequent historically.
3Mb FTTC
23-11-2011 9:33 AM
Quote from: godsell4 There is no difference if I use the test socket
How do you mean? I think a period of time in there would help us a lot more. As far as any fault testing goes this would be a requirement, so I think that's the first thing we should do.
Jojo
23-11-2011 9:51 AM
3Mb FTTC
23-11-2011 9:58 AM
If you plug an in-line filter into the test socket you still have a socket for the phone. The thing is, if we raise a fault to our suppliers and they say "is the customer in the test socket" and we say no, they'll just pass it back until you are. It's not a case of me insisting, it is a requirement of the fault process.
Jojo
23-11-2011 10:52 AM
3Mb FTTC
23-11-2011 11:03 AM
23-11-2011 3:55 PM
Yep, as expected, it shows frequent dips in the SNR. This is not normal.
3Mb FTTC
23-11-2011 4:01 PM
Any noticeable noise on the line? Have you run a quiet line test?
23-11-2011 5:40 PM
A good question, audibly there no significant clicks, pops or other artefacts which I would consider to be unusual. To listen to a quiet line, I jusy took the phone off hook and pressed the 0 button to cancel the dial tone.
SW.
3Mb FTTC
23-11-2011 6:22 PM
3Mb FTTC
23-11-2011 10:41 PM
Quote from: godsell4 To listen to a quiet line, I jusy took the phone off hook and pressed the 0 button to cancel the dial tone.
Dial 17070 then 2 for the Quiet Line Test
