Idiot's guide to bridge mode
FIXED- Subscribe to RSS Feed
- Re: Idiot's guide to bridge mode
4 weeks ago
4 weeks ago
4 weeks ago
@Junkman Is the DMZ set in the Hub 2 ? if so then check that WAN ping is enabled on the Billion
4 weeks ago
After a night sleeps that is my thinking as well, inbound pings are going to the device defined in the DMZ
4 weeks ago
Morning chaps,
The DMZ is on in the Hub 2 and the Billion IP address is in it. And block WAN Ping was already disabled on the Billion (see screenshot attached) so it can't be that I'm afraid
4 weeks ago
Morning,
Maybe try turning off "Allow incoming ping requests to the Hub's public IP address" on the Hub Two, provided a device in the DMZ is enabled for WAN ping reply the BQM should work.
4 weeks ago
@Junkman Can you do a screenshot of the DMZ setting in the HUb 2 please ?
4 weeks ago
@MisterW screenshot attached.
@Dan_the_Van just did that but will be a little while before I can see if it's had any effect on BQM
4 weeks ago
@Junkman sorry to be a pain but could you do another one with the Show IP button checked ?
4 weeks ago
Just for reference , theres a thread here regarding PQM pings and the Hub 2 https://community.plus.net/t5/My-Router/Plusnet-Hub-2-Incoming-Ping/td-p/1850036
As we suspected It SHOULD work either with ping enabled on the Hub 2 OR with DMZ and ping enabled on the 8800
4 weeks ago
@MisterW not a pain at all - attached
4 weeks ago
@Junkman well that certainly looks right to me, that IP agrees with the WAN IP that the 8800 had yesterday and I see no reason why that would have changed.
Did @Dan_the_Van s suggestion
have any effect ?
4 weeks ago
@MisterW unfortunately still solid red on the BQM chart. As I said yesterday I think it worked for about 2 hours after I got the connection up. Probably went red after I'd disconnected again to sort out all the cabling.
I'm synced at 25.8 this morning but can't tell if DLM reset last night without the BQM 😕. I was synced at 32+ with just the Billion. Of course be good to get the BQM back before I talk to Plusnet on Monday.
4 weeks ago
@Junkman yes you can, you can look at the Hub 2 event log. IIRC its advanced-troubleshooting-technical log. You can even export it as a csv and post it here if you need help in reading it.
4 weeks ago
@MisterW unfortunately the Event Log only goes back to when I booted my laptop this morning
