How do you get PN to actually do something ?
- How do you get PN to actually do something ?
Re: How do you get PN to actually do something ?
23-01-2012 3:44 PM
23-01-2012 4:34 PM
23-01-2012 5:08 PM
I had hoped that the loss of sync today was due to the snrm being reset, but obviously not
If or when the BT engineer files his report, he needs to be made aware that he has actually made things worse rather than better, I don't want him thinking that it's all sorted.
Dave
23-01-2012 5:24 PM
Give me a nudge in the morning just to remind me.
Jojo
24-01-2012 10:21 AM
Nudge Nudge
i have just rebooted the router but still 9
I also noticed >300 CRC Errors - I think this new line has bigger issues than my old line
Dave.
24-01-2012 10:33 AM
Still can't see any change here either. I'll have to give it the 24 hours so will check later and take some advice on whether to do it again.
Jojo
25-01-2012 8:04 AM
Another Nudge as requested....
Just tried rebooting router, stil <10Mbps sync, 35dBi Atten and 9dBi SNRM
[Was >14Mbps sync, 31dBi Atten, 3-6dBi SNRM & 12.1Mbps download speed]
Has the BT engineer filed his report yet
We need to get him to undo whatever change he made as I am now 33% worse off than I was last October
Dave.
25-01-2012 8:48 AM
Looking at your connections from the time I placed the reset we had a number of disconnections. Now, for all I know the SNR may have gone down, couldn't cope with it and went back up. I don't want to mess around with things too much, as there's already quite a lengthy fault investigation. I think we should wait and see what the faults team find out at this point before tinkering anymore.
Jojo
25-01-2012 12:17 PM
OK, well, as previously mentioned, the first weekend glitches / dropouts occurred the weekend before I was upgraded to 21CN.
I think my exchange was actually only upgraded to 21CN at that time or possibly just before my first dropout occurred.
So, once on 21CN I initially synced at approx 12Mbps, which then rose to 14Mbps by 5th Oct and stayed there until sometime after 16th Nov, during which time I could download at 12.1Mbps, my SNRM was either 3 or 6dBi and my attenuation was 31dBi. I still did suffer from the occasional weekend glitch during this period.
Approx one weekend in 4, from when my exchange was upgraded, I would experience either a loss of connection or a freezing of my connection. This would normally last until exactly 7pm at night at which point it would then be OK again and I would then be able to download at 12Mbps again.
During the “freezings” if I tried to do a speed test (My Broadband) the needle would scream up to 12.1Mbps and stay there until suddenly the Orange bar at the bottom of the screen would pause or freeze about ½ way across and the rev counter would fall back towards zero, then it would start moving again and the rev counter returned to 12.1, this start / stop “freezing” may occur once, twice or several times during the test.
Since 26th Nov after a Weekend of problems I have not able to sync at more than 12Mbps and over the past few months this had dropped still further to only 10.5Mbps. At the same time my attenuation had increased from 31 to 33dBi.
However, after the BT engineer swapped the pair between my cabinet and the exchange last Friday, things have got considerably worse. I can now only sync at 9.7Mbps, my Atten has risen to 35dBi and my target SNRM has jumped to 9dBi.
Value Previous Current
Sync 14.414 9.7 Mbps
Attenuation 31 35 dBi
SNRM 3-6 9 dBi
D/L Speed 12.1 8.5 Mbps
This represents a 33% drop in performance since October and November 2011 and I am not at all happy !
25-01-2012 2:46 PM
26-01-2012 1:26 PM
Also they made no mention of the fact that the service has degraded by some 33% since October !
Anyhow, I will restart the router when I get home in 4 hours as instructed and we will see... but how just resetting the line will correct the 4dbI increase in attenuation, I am at a loss to understand, as that will require me to be put back on a good pair like I was on last October surely
Dave.
26-01-2012 7:06 PM
I restarted it again at 18:30 just in case, but still only syncing at 9,727,058bps, SNRM is 8 and Atten is still a very high35dBi.
As expected just resetting the line without correcting the faults first, has made absolutely no improvement, I am also very disappointed that the PN tech support guy though otherwise ?
So another week wasted and still no further forward, in fact each time PN/BT try to correct the fault, things just get worse, I wish I had never reported the fault, I might still be syncing at 14Mbps instead on 9Mbps.
EDIT - still no change at 20:15
27-01-2012 9:59 AM
I have attached a graph which shows how the speed has dropped since BT swapped the line (where it drops below the greem line at the right)
I have also included 2x DMT printouts from my old Voyager router, I can't say I understand them, but they may throw some light on wht it has dropped so much.
David.
30-01-2012 1:41 PM
I've raised a new fault with our suppliers and contacted them to have the profile changed. This should lift the restriction that has been placed on your sync rate. They say the change will take 2 hours to take effect. I'll test it again in a bit but if you could also keep an eye on your sync rate to see if it goes over the 9726 I'm seeing at the moment.
Jojo
30-01-2012 4:43 PM
The banding has now been removed and your line is syncing at 12664. I have changed your profile to 11100 to allow for you new profile. This should take effect shortly. I can see that there are a number of errors on the line. Are you still in the test socket?
Jojo
