Disconnects/Noise margin problems after dark
- Re: Disconnects/Noise margin problems after dark
- « Previous
- Next »
02-12-2012 9:00 PM
Quote from: Anotherone Anyway it's not a Target Noise Margin change that's required as ReedRichards has incorrectly implied...
I beg your pardon?
Quote from: Anotherone In time it will drop the Target SNRM as well as long as things look stable enough and the error rate is low enough.
Agreed
03-12-2012 1:42 AM
03-12-2012 10:04 AM
03-12-2012 12:59 PM
No real joy in seeing what the jumps on the SNRM graph are. It looks as though PN have updated the IP profile this morning though:
Estimated line speed:
8Mb (This may vary between 6.5Mb and 9.5Mb) - Checked on 2012-11-30 13:57:55
Current line speed:
9.4 Mb
04-12-2012 12:37 AM
04-12-2012 8:25 AM
Unfortunately though I have to report having another resync last night, noise margin was ~8.6 at the time and it dropped the speed to 10331 on reconnect. Again this morning it resynced back up to 11148, I'm beginning to think I have a duff router that is incapable of dealing with any kind of noise on the line at all.
05-12-2012 12:25 AM
05-12-2012 8:07 AM
As an aside looking at my router this morning it has a very large value for "CRC" (currently 21,000) which I noticed was only ~150 when I went to bed last night after actually using the internet quite heavily all evening without the slightest hitch. Could these be CRC errors and the router resyncs when it reaches a certain threshold? As I've been sitting here for about 30 minutes that value has gone up by about 5000, just as dawn is breaking. The only other thing happening in the house is the washing machine was finishing up a spin cycle at around the same time.
What the router is reporting:
Downstream Upstream
SNR Margin : 10.2 6.0 db
Line Attenuation: 37.0 20.1 db
Data Rate : 11118 1079 kbps
Max Rate : 11816 1080 kbps
POWER : 0.0 12.3 dbm
CRC : 21054 0
EDIT: to add there was nothing going on downloading wise or whatever overnight, my useage 12pm - 8am was 11.69MB, most of which was forum reading this morning.
05-12-2012 6:15 PM
I would try and monitor what's happening to noise levels and errors when your washing machine is in use in future, electric motors can generate loads of interference if the brushes are on the way out, or a dirty commutator, or lack of/failing suppression, or even the switching if contacts aren't making and breaking cleanly.
The dip at 0930 and off at 1045 pm, something obviously switched on for the day, possibly not in your house, but check for things like the sky box, TV, fluorescent lights (all types), low voltage halogen, even mains LED bulbs I've even heard can chuck out some noise - that's bad design if they do! * anything else you can think of that might be switched on for that sort of timescale, including computers and monitors.
Edit: don't forget to adjust the plotting to see if we can spot any noise spikes!
05-12-2012 7:27 PM
05-12-2012 9:00 PM
@Anotherone the SNRM didn't ever approach zero that I could see, the connection just dropped out from ~8.6db. It's easy to tell when it is about to happen as everything just slows down to dial up speeds for a minute or so beforehand so when that happens I tend to switch over to RSL to watch it go.
I've got the plots adjusted as you suggested but I'm not really seeing anything different. Obviously I haven't had another event since then though, although it has been slowing up a bit tonight with the CRC count going crazy again so we might get "lucky". 8.5db now appears to be the new zero for me
06-12-2012 12:38 AM
07-12-2012 12:23 AM
What was the DS SNRM exactly immediately before you did the resync? Seeing the graphs for all that may help.
07-12-2012 8:04 AM
Current stats:
Downstream Upstream
SNR Margin : 11.4 6.0 db
Line Attenuation : 37.0 20.1 db
Data Rate : 10117 1072 kbps
Max Rate : 12548 1076 kbps
CRC : 248 0
I've attached 2 graphs, one for when I did the manual resync which shows the SNRM pretty constant at about 8.5 as things were slowing down on Wednesday and a second which looks like it shows a dropout which happened during the day yesterday, although the connection speed looks to have remained the same after the event with that one. I wasn't using the internet at the time so I can't say whether or not there was any slowdown before this happened or not.
07-12-2012 11:44 PM
The sooner that you can positively eliminate any equipment as potential noise sources by doing some methodical checking, the better.
If you are able to try/borrow another modem/router just to check whether the symptoms are the same and eliminate that from the equation, that would be a good idea.
- « Previous
- Next »
