Cant Connect to my VPN
- Re: Cant Connect to my VPN
- « Previous
- 1
- 2
- Next »
25-01-2012 11:03 PM
Linksys WAG54G v2 and v3 work well, and are cheap on eBay !
Message 16 of 18
(253 Views)
26-01-2012 6:28 PM
Thanks for the router names.
Can someone confirm if they are using a Belkin router for VPN and if so which model.
I am using Belkin G+ MIMO Router - F5D9630-4 ver 4002uk.
I cant connect to my VPN using this router. Is anybody else having or had this problem?
Many Thanks
Many Thanks
Message 17 of 18
(253 Views)
31-01-2012 10:54 PM
Used my old BT Voyager 105 Modem fixed line to test VPN and guess what it worked
Is anyone using a belkin modem (G) which works VPN.
I just want to know why I cant get my belkin wireless modem/router to work.
Message 18 of 18
(253 Views)
- « Previous
- 1
- 2
- Next »
