Billion 5200G
- Re: Billion 5200G
Billion 5200G
18-09-2008 12:09 PM
When I changed my router to wpa it stopped working.
Message 1 of 7
(1,566 Views)
6 REPLIES 6
Re: Billion 5200G
18-09-2008 12:43 PM
What exactly stopped working?
Message 2 of 7
(649 Views)
Re: Billion 5200G
18-09-2008 12:52 PM
No connection.
Message 3 of 7
(649 Views)
Re: Billion 5200G
18-09-2008 12:59 PM
The award for 'Thread with the least amount of words per post' goes to....
Could you explain which connection stopped working? ie - the connection between your pc/laptop and your router, or your internet connection?
J
J
Message 4 of 7
(649 Views)
Re: Billion 5200G
18-09-2008 1:02 PM
What happens if you reboot your router?
What happens if you go back to WEP or whatever you useed previously?
Have you had a look at how the manual explains to allow WPA?
What are the lights on your router doing?
Message 5 of 7
(649 Views)
Re: Billion 5200G
18-09-2008 1:13 PM
I take it you have also told your PC to use WPA and told it the correct passphrase?
Message 6 of 7
(649 Views)
Re: Billion 5200G
18-09-2008 7:10 PM
When I tried to reconnect,my computer threw up a message about it not being optimised. Attached an Ethernet cable and changed back to 'wep open' and it was fine again.Was able to use the wireless.
Message 7 of 7
(649 Views)
