BT Wholesale Broadband Performance Test FTTC
Fixes: 162
Re: BT Wholesale Broadband Performance Test FTTC
Quote from: Chris
I'll pass the feedback on, however, my main concern at the moment, is ensuring that it works, especially the TAP3 side of things.
Chris,
Is the need to wait before thus test can be run documented in your FTTC guide?
Kevin
Pettitto
Fixes: 5
@Xreyuk - Yep, I'll speak to our suppliers tomorrow and see what we can get done on that for you.
@Townman - Sure, good shout. I'll add that tomorrow Smiley
xreyuk
No problem, thanks Chris Smiley
dick:quote
Jaggies
TAP3 test still not working here.  Undecided
petecov44
I will wait until 14 days after my install and see if I can get it then
Pettitto
Fixes: 5
@Townman - I've added that detail onto the guide.
@ Xreyuk - I'm speaking to our suppliers about this now.
Pettitto
Fixes: 5
@Xreyuk @petecov44
Just so I can pass these on to push for a permanent fix for the issue where this continues to still not work after 14 days, would you both be able to provide screenshots of the Speed Test not working correctly along with the time and date showing as Jaggies has above.
Petecov44 - I'm asking if you would be able to provide so I have screenshots from throughout the 14 day period.
goldenfibre
Seasoned Pro
Fixes: 12
@Petecov44 - I thought u have fibre of more than 28 days now? Or have you moved again? There is no metion of your username on my plusnet referral scheme on my account for nearly 4 weeks now.
Pettitto
Fixes: 5
@petecov44 @Xreyuk
Can you both please run the PTTR at your earliest convenience so I can pass this back to ASG Team? As soon as I hear back, I'll try get this sorted out for you.
goldenfibre
Seasoned Pro
Fixes: 12
Chris I like this one below, could u sent me one of my line result the same what u just added screenshot below please:
Pettitto
Fixes: 5
xreyuk
Chris, I'm assuming the speed test result doesn't matter?
Would I be okay to just run the test from work and when I go for additional information just put my number in, or would you prefer me to run her actual test on my line?
My thinking is that the tester doesn't care what speeds you're getting, you're just trying to retrieve the info using your number.
Pettitto
Fixes: 5
Ideally, if you're able to do it from home, that'll be best as I believe the test also reports on the IP address that you were assigned at the time too.
There's no immediate rush if you can't do it until tonight for example.
petecov44
@Chris
Sure I will do one each day for 14 days and send them to you.
@golden. I've moved again and I am not being connected back to fibre until Monday.
@Xreyuk  IP address, Time,Date, Username used during testing. All sorts of wonderful stuff Smiley
goldenfibre
Seasoned Pro
Fixes: 12
Thanks Chris, I can see my line is very healthy since FTTC went live last February. Very happy overall with your excellent service from Plusnet. @ petecov44 - thanks for letting me know. Maybe u get a better FTTC in your new place. Wink
