Am I stuck with 4000mb?
- Am I stuck with 4000mb?
Re: Am I stuck with 4000mb?
26-09-2011 1:24 PM
I would suspect it’s the original socket that was put in when it was built almost 30 years ago.
26-09-2011 1:32 PM
26-09-2011 1:52 PM
Also do you recommend leaving the router on 24/7?
And While I ‘m here, my exchange has 21CN WBC enabled. Is it worth pursuing a switch to ADSL2+ ?
Thanks again for your help.
26-09-2011 2:57 PM
Until your line is shown to be stable I wouldn't switch due to the harsher error responses on 21CN
Can you report back the router stats tomorrow
26-09-2011 4:00 PM
You're already on 21CN on ADSL1 and on the cusp of being beneficial for being switched to ADSL2+. Your profile has now increased to 4500 so you should see that change shortly.
Jojo
28-09-2011 12:27 PM
Initially I did see an improvement of about 500 to 800 on the router settings and the BT speedtester showed a connection range above 7000, but it’s slowly come back down to close to the levels I had before but it does seam a lot more stable with not so much fluctuation, but the max connection range is now back to 4000.
I’ve moved back to the extension now as there really wasn’t mush difference in the results and it’s simply not practical to have the router in the hallway as I’d need to upgrading xbox’s and pc to wireless. FTTC is on its way to my exchange early next year, that may be my best option if ADSL2 isn’t an option.
Thanks Again.
28-09-2011 1:35 PM
Could you post your current router stats - like those you posted in reply #4?
28-09-2011 1:51 PM
ADSL Firmware Version: 6.00.01.00 - 6.00.01.00 - 6.00.04.00 Annex A - 01.07.2b - 0.54
ADSL Software Version: V3.00B01T01.20060721
Line State Connected
Modulation ADSL_G.dmt
Annex Mode Annex A
Max Tx Power -38 dBm/Hz
Item Downstream Upstream Unit
SNR Margin 13 24 dB
Line Attenuation 39 23 dB
Data Rate 4576 448 kbps
28-09-2011 2:09 PM
28-09-2011 2:43 PM
28-09-2011 3:28 PM
Nothing tried nothing gained.
Do I need to raise a ticket or can my request be picked up from here?
28-09-2011 3:44 PM
Spraxyt is normally correct, but I dont think it is easy to switch back as it uses a different board in the exchange. It wont harm to ask the question
28-09-2011 4:56 PM
I think raising a ticket/question to request the change with the possibility of reversal is the way forward. I'd include a reference to this topic.
28-09-2011 5:09 PM
If you raise an ticket, do let me know and I'll action it for you.
Jojo
28-09-2011 5:11 PM
