A TG585v8 Question
- Re: A TG585v8 Question
A TG585v8 Question
17-06-2012 12:01 AM
Hi guys i was just wondering what these do (Highlighted in red) i cant find any answers on web. Cheers
Message 1 of 2
(613 Views)
1 REPLY 1
17-06-2012 2:50 AM
Well, the trigger port opens up the ports you've set to it. So when the trigger port is not used those other ports will be closed. Trigger port is an outgoing connection, if you didn't work that out already.
That's RPM to you!!
Message 2 of 2
(236 Views)
