Wireless Set Up
- Wireless Set Up
Wireless Set Up
16-06-2012 8:56 PM
hi, just switch to plus net and trying to set up wireless, but got following messaged when used plus net assist. Don't understand why as I had wireless with previous supplier. Was using Netgear 54 mbps Wireless ADSL2+ mODEM ROUTER DG834G. Can somebody explain? thanks.
We've detected that your computer does not have wireless capability. If you want to use wireless connection on this computer you'll need to purchase a wireless USB adaptor or card before you can go online wirelessly.
Most high-street electrical retailers will be able to supply you with a wireless network adaptor suitable for your computer.
Plusnet Assist will be able to help you get connected if you decide to fit one.
dick:red All caps title edited as per forum rules.
Message 1 of 2
(598 Views)
1 REPLY 1
Re: Wireless Set Up
16-06-2012 10:37 PM
Since you aren't using a Plusnet supplied router Plusnet Assist is a total waste of space - just ignore it
Message 2 of 2
(265 Views)
