Turn my interleave off
wilma1964
Please turn off my interleave !!
18 REPLIES 18
Chris
Legend
Fixes: 169
Re: Turn my interleave off
I've just had a look at your line and I'd strongly advise against turning interleaving off at the moment. Your line isn't near stable enough to cope with this additional error correction.
Looking at that graph I'd also suggest you go through the faults checker at https://faults.plus.net as something isn't right there.
wilma1964
Most of them is me trying to change settings out of pure frustration please turn it off if it fails ill put back on lagging and button delay day and night is really getting on my nerves
Chris
Legend
Fixes: 169
Can you leave your router powered up and don't disconnect it please. We really need to see stability before turning interleaving off. If the line proves stable enough over the next 24 hours we'll place the order.
x47c
All very interesting:
....as I thought that ISP's have no control over the interleaving status on the FTTC service and that it is all automatically determined by BT's DLM system which is the ultimate decider of what the line setting should be.
Chris
Legend
Fixes: 169
We don't have control over the DLM, to remove interleaving is a bit of a pain as we have to place a modify order to make any changes to interleaving.
kitz
Quote from: Chris
Interesting. Unlike ADSL, there is no specific 'Interleave' option in a modify order.
Not knowing the parameters hidden away under "DLM" for an FTTC modify order.  Why does that actually do?  Is it a full reset of the DLM, or just (temporary) removal of interleaving?
Chris
Legend
Fixes: 169
@kitz
Let me double check, I may be remembering it wrong but I thought there was an option for auto, on or off for interleaving. If not, then I'm sorry wilma1964, we'll have to allow DLM to do it's job, but it's a much better idea to allow the line to be connected consistently.
Chris
Legend
Fixes: 169
Kitz and x47c are correct, even a modify order doesn't specifically let us alter the interleaving. The only real thing we can change is the stability option.
There's some discussion of this here: http://community.plus.net/forum/index.php/topic,132641.msg1158780.html#msg1158780
kitz
Thanks for getting back Chris.
Thats a shame as I bet some people were getting excited that there may be a way to do it.
Chris
Legend
Fixes: 169
It is a shame really, I hope we get some additional tools to be able to  do this but at the moment our hands are tied.
goldenfibre
Seasoned Pro
Fixes: 12
I thought DLM was turned off by BT as of 21/11/14?
Chris
Legend
Fixes: 169
As per the other thread, which is where we should keep this discussion, we've got nothing more to add at the moment on the impact of these changes.
Even if DLM has been turned off, that doesn't suddenly mean we have new tools to remove interleaving etc.
sjptd
I hadn't noticed the lack of DLM, though I did notice this morning that a intermittent severe brown-out and two power cuts had left me with higher sync speeds.
For more details on goldenfibre's comment (I thought DLM was turned off by BT as of 21/11/14?) see http://www.thinkbroadband.com/news/6726-assia-court-case-forces-openreach-to-turn-off-dlm.html
What I would like is a capability to increase target SNR and stability at the cost of a lowered sync speed.  I guess I could get that with a more advanced modem, but not (as far as I know) on an HG612, even unlocked.  I'm on PlusNet 40/20 with SNR of 5.1 and a wasted sync speed very close to 80.
chrcoluk
can plusnet confirm if doing a modify order to change the product resets DLM or not e.g. moving from 80/20 to 40/10 on the openreach product, if yes why do plusnet say they cannot do this?
