Billion 7800N: Not Working!
sjrinfroyle
I have got everything setup for IPv6 but it is not working. Any ideas?
56 REPLIES 56
adamwalker
Fixes: 223
Re: Billion 7800N: Not Working!
You're not on the trial, which could be a good reason why. We're giving different login detail for those that are so that they can be assigned a V6 IP.
 Adam Walker
sjrinfroyle
I am on the trial, I have been given the login details.
adamwalker
Fixes: 223
Seeing a lack of reply here http://community.plus.net/forum/index.php/topic,96321.48.htmland nothing marked on your account made me think otherwise. Can you tell me what's happening?
 Adam Walker
sjrinfroyle
I am getting no IPv6 DNS addresses.
sjrinfroyle
If anybody has anys suggestions please let me know. I am not getting a gateway IP address or DNS addresses. I am on the trial and this has been confirmed by Ben Trimble.
BenTrimble
Just to clarify, sjrinfroyle is connecting on the IPv4 address issued to the IPv6 test account, looks like it's a router / computer config issue but I'm no expert to look into the problem!
adamwalker
Fixes: 223
Ben's confirmed that you are definitely on the trial and seem to be connecting to the trial account just fine.
Yep, we've noticed that you've posted from the v4 IP though, that suggests you need to change your config to specify the V6 address or allow the router to pick that up automatically.
I'd also advise checking the info posted here: http://community.plus.net/forum/index.php/topic,96141.msg810534.html#msg810534
 Adam Walker
sjrinfroyle
I have followed that post carefully but I am still having a problem. IPv6 is enabled on my Billion 7800N but no gateway IP is being picked up.
sjrinfroyle
I might be able to configure it manually. What is the Plusnet IPv6 gateway address?
brueton
Have you seen my posts on a problem I am having with IPv6 on the 7800N?  http://community.plus.net/forum/index.php/topic,97833.0.html
The issue is still unresolved. I have some notes regarding my setup and also some notes on a manual workaround.
I would be interested to hear if you are having the same problem.
I can PM either of the notes to you.
Currently trying out 1.06f from the aussie. website but it has made no difference.
Waiting for one of the trial IPv6 582n routers to arrive to see what it will do.
Regards
PeteB.
sjrinfroyle
If you could PM the notes it would be appreciated.
sjrinfroyle
I don't seem to able to pickup any IPv6 address from Plusnet, it doesn't appear on the status page on the router. I only get the IPv4 address.
brueton
Notes PM'd.
PeteB
sjrinfroyle
Thank you for the PMs. On the Configuration - WAN Profile page, under Obtain IPv6 DNS, do you get any numbers in primary or secondary?
My problem seems to be that I am not getting an IPv6 address, I am definitely on the trial.
