Billion 7800N: Not Working!
BenTrimble
Re: Billion 7800N: Not Working!
About half made it into today's post, the rest will go tomorrow and yes, hobnobs would be lovely thanks Smiley
sjrinfroyle
Still having problems. Not getting any DNS or gateway from Plusnet. Even the fix isn't working.
adamwalker
Fixes: 223
I can see that you're connected to the right account and you're being served a v6 IP now, so that's a step in the right direction. Try specifying the DNS servers, we don't have our own IPv6 caching servers so we're using Hurricaine Electric's DNS: https://dns.he.net/
Hope that helps,
Adam.
 Adam Walker
sjrinfroyle
Is it still working?
sjrinfroyle
Adam, the problem seems to be with the gateway from Plusnet. I am only being assigned the IPv6 address from the router.
sjrinfroyle
Is there a manual IPv6 gateway address that I can enter?
adamwalker
Fixes: 223
There's no issues with the gateway itself so I'm not sure why that is.
It might be worth your while asking if any other customers are using the 582n on IPv6 to post their config for you.
I'll be off shortly and won't be back until the new year so have a good Christmas Smiley
 Adam Walker
sjrinfroyle
I have a good update! I tried firmware 1.06b-6 from the Australian Billion site and IPv6 works without needing to do the fix! It connects first time and works 100%. PeteB: would you like to try 1.06b-6 to see if it works for you as well?
sjrinfroyle
Results of an IPv6 test with the 1.06b-6 firmware on the Billion 7800N:
brueton
Hope to try it out early tomorrow morning.
Using the trial 582n at the moment.
PeteB
brueton
IPv6 and 1.06b-6 is NOT working for me. I have tried Windows 7, Vista, Android & Linux.
Will investigate further when I get some time to spare.
PeteB
sjrinfroyle
It's either a coincidence or it's the firmware. But after doing a factory reset it is still working.
