surround sound
- surround sound
surround sound
08-03-2008 7:35 PM
built myself a media center and i am trying to figure out the best way to setup a surround sound system to go with it. can i just use the audio out put from the motherboard which is 5.1 or should i come of the back of the TV and then into an amp ect?
4 REPLIES 4
Re: surround sound
08-03-2008 7:38 PM
oh gosh, another serious thread - on a Saturday night too!
Re: surround sound
08-03-2008 7:39 PM
To use surround sound you need four speakers, one in each corner of the room, and look in your sound card settings to see if it supports surround sound..... I remember my W95 desktop did, and you had a test which simulated a helicopter flying round your front room...........
And I fell for it ............ hook, line, and soundcard
Quote from: jmd oh gosh, another serious thread - on a Saturday night too!
Re: surround sound
08-03-2008 7:49 PM
and dont forget the one for the young idiots that goes bump bump in the front middle
Dont think TV's give out 5.1 only DVD (and Maybe HD)
Re: surround sound
08-03-2008 7:59 PM
If you want to go high end, get a soundcard with optical out and a surround sound amp with optical in (and a decent speaker set). If you're not too worried about spending loads, get a powered speaker set and just use 3.5mm jack -> phono leads to connect it up.
