"Press any key to boot from CD"
seanbranagh
Just built my new machine and going to install windows. It is just going ahead and booting from the CD and not giving me the option to "Press any key to boot from CD" How do I fix this?
The computer has 2 DVD drives IDE and 2 SATA Hard disks.
21 REPLIES 21
jelv
Fixes: 10
Re: "Press any key to boot from CD"
Have you checked the BIOS settings?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Oldjim
Resting Legend
Fixes: 63
Sean,
A word of warning.
If you are going to install widows on the SATA drive disconnect all the IDE hard drives first otherwise it will stick some of the files on the IDE drive regardless
seanbranagh
The HDD's are both SATA. The only PATA drives are the 2 DVD Drives. The computer is booting from the DVDROM without giving me the option to "press any key to boot from CD" as if it is a HDD.
In the BIOS I have set the drives to CDROM but it made no difference.
pierre_pierre
in the end do what it says
Dont hit me please
Oldjim
Resting Legend
Fixes: 63
I may be wrong on this but I think it only gives the option if there is already an operating system installed on one of the hard drives
seanbranagh
No. Windows XP always gives the option. Linux usually does not.
Oldjim
Resting Legend
Fixes: 63
I obviously misunderstood your first post
as I thought you hadn't yet installed windows
chillypenguin
Quote from: Sean
That's your mistake.
If you must install Windows, Install Linux + VMWare then install Windows in a Virtual Machine.
That way you could get rid of one of your servers.
http://www.chillypenguin.org/vmware/vmware.htm
samuria
The press any key is an option that you set when building a bootable cd and you can set it not to ask and boot straight into the cd. If the cd is rebuilt ie someone has added the sp3/sp2 they may have unticked this option which is a pain because you start the install go and have a cup of tea and come back and its rebooted and started again.
see
http://www.nliteos.com/nlite.html
This tool lets you change loads of things on the  xp boot disk and you could re write the cd to use the press any key. If you are building a cd its very easy to miss the press any key. Its worth looking at as you can add drivers, set defaults you want and make the cd install without having to touch it or answer any questions
seanbranagh
I fixed the problem. It was because I had connected the DVD drives using an IDE cable supplied with the motherboard clearly marked HDD Cable. I didn't realize there was a difference.
I knew the CD did display the option because I have installed it before. Everything is now installed (I am now using the new computer). It is lightning fast compared with my old Athlon XP 2400+ (Which is now in one of my servers).
The gigabit ethernet is also a big improvement between the new computer and the server that I upgraded from the old motherboard (Bought a card for the server and a new switch).
Specs are:
Phenom 2.6Ghz x4
4 Gb DDR2 800 (Although XP can only see 3Gb)
2 x 250Gb SATA HDDS
Oldjim
Resting Legend
Fixes: 63
Quote from: Sean
I have quoted this because I have never heard of it before. Can anyone shed some light on it
chillypenguin
I can sort of understand if one of the DVD's drives was IDE0 Master, but not just swapping the cable.
artificer
is it anything to do with 40 column and 80 column ribbon cables?
that looks a nice box, sean.  one of those 'easy-fix' setups that allow the swift interchange of parts.  can sata mobos support more than four drives?
HPsauce
Quote from: artificer
Possibly, but the only cable on view looks like an 80-core CS type.
(Though the 80-cores are actually to support higher DMA modes not CS, but they usually go together)
Sean, do you need any explanation re cable types/connectors and jumper settings (MA, SL, CS) on IDE disks and Optical drives?
