How do I???????
kreynolds
How do I???????
Connect a blu ray player to a wireless networkHuh?
Running a Netgear DG834N Rangemax router which is based upstairs and is WDS capable.  I want to hook up the player to the internet so I can get the BD Live content and firmware updates - the player only has a wired ethernet port.
Ta
Fixes: 341
Re: How do I???????
What is the make and model of your player? You might be able to download it offline and install it.
Otherwise it might be worth looking at a wireless bridge that you can hook up to your ethernet port on your blu player http://www.expansys.com/p.aspx?i=127730
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 60
Re: How do I???????
You might want to take a look at this clever piece of kit http://www.solwise.co.uk/3g-routers.htm
One of its modes is as a 'Wireless Client', connect your player to one of its ethernet ports and you should be able to connect to your wireless network.
