emails
sixpence
emails
where's the email log in box gone?
Fixes: 50
Re: emails
What login box...this one https://webmail.plus.net/src/login.php
Customer and Forum Moderator.
Fixes: 8
Re: emails
sixpence is right. I do remember there used to be a webmail login on the front page of the member  centre - not that I ever used it.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 50
Re: emails
Oh I see....it's something to do with this.
I hadn't realised from the opening post. Huh
The link is still there top right though.
sixpence
Re: emails
"What Log in Box"? The one that used to be on the front page of plus net just above the News. Suggest you check with Plus net.
Fixes: 50
Re: emails
Sorry sixpence I hadn't noticed it as I go into webmail a different way Embarrassed
pierre_pierre
Re: emails
do you mean this one?
sixpence
Re: emails
Thanks Strat,
In my ignorance thought there was only one way to log in  to emails.
no worries. Cheesy
Re: emails
Well it's there today!  Huh
