CD Autostart
Fixes: 9
CD Autostart
Seem to have installed something on my computer which is preventing CD/DVDs from auto running but I can't remember how to switch this back on.
Other problem is that external drive is not coming on automatically... easy enough to activate these things using windows explorer but I would rather just switch the auto run back on.
Fixes: 20
Re: CD Autostart
Assuming XP.
Open Regedit
locate
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionpolicies
delete the NoDriveTypeAutoRun value
Fixes: 9
Re: CD Autostart
Thanks for that but I am only half way there.
The external drive now loads up fine but the internal cd/dvd still refuses to auto start disks.
Fixes: 62
Re: CD Autostart
This tells you how to disable it - logically reverse the process http://support.microsoft.com/KB/126025
Fixes: 17
Re: CD Autostart
Digging a bit further on that linky..... (check out the column on the right hand side of the page) I found this
• The AutoRun feature or the AutoPlay feature does not work when you ...
(330135) - Explains why a CD-ROM may not start to play automatically when you insert it in your CD-ROM drive. Provides a step-by-step resolution.
http://support.microsoft.com/kb/330135/en-us
Fixes: 9
Re: CD Autostart
All sorted now via the microsoft help page,
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom
1. Double-click Autorun and see whether a zero or a one is displayed in the Value data box.
o If the value for Autorun is 1, go to step 5.
o If the value for Autorun is 0, right-click Autorun, and then click Modify. In the Value data box, type 1, and then click OK.
2. Locate and then click the following subkey:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
3. Double-click NoDriveTypeAutoRun to see its value. If the value is 0xb5, the AutoRun feature for CD-ROMs is turned off. To turn on the AutoRun feature, follow these steps:
a. Right-click NoDriveTypeAutoRun.
b. Click Modify.
c. In the Value data box, type 91.
d. Select Hexadecimal, and then click OK.
Exit Registry Editor.
Thanks for your responses
VileReynard
Seasoned Pro
Fixes: 10
Re: CD Autostart
And some would say that Linux is hard. Grin Grin Grin
