Youtube/Adobe Problem
artmo
Aspiring Champion
If this is in the wrong forum could a Mod please move it for me?
When I use Youtube I get a box appear on the screen. Clicking 'allow' often doesn't get rid of it. When 'allow' does get rid of it it reappears later. I have followed the instructions from Adobe but the box reappears the next time I use Youtube.
It's a nuisance. How can I get rid of it permanently?
7 REPLIES 7
Oldjim
Fixes: 63
Re: Youtube/Adobe Problem
which browser are you using
artmo
Aspiring Champion
Firefox 30.0
Oldjim
Fixes: 63
If you go to Tools then Options then Applications is anything listed there under Flash Player
artmo
Aspiring Champion
No. The only Adobe items listed are for Acrobat.
rongtw
Fixes: 12
http://blog.chron.com/helpline/2013/04/what-is-s-ytimg-com-and-why-does-it-want-access-to-my-compute...
have a read here , it should be fine to allow
Oldjim
Fixes: 63
artmo
Aspiring Champion
@Oldjim and @rongtw, thank you both for your advise. Followed instructions and it looks like my problem is solved.
