You are not in the UK
- You are not in the UK
15-09-2016 7:22 PM
I have no problem downloading and using the BBC iplayer, ITVHub or All4 but when I try to use UKTV which installs ok I get the message, you do not appear to be in the UK and can only watch this if you are in the UK ?
Why would UKTV not recognise Plusnet as being in this country or is this problem down to something else ?
Not important if this can't be solved, I am more curious than anything.
Using Android tab.
Re: You are not in the UK
15-09-2016 8:02 PM
Sometimes in the past when i used Teamspeak voice coms it shown me being in america when i was in the uk, could it be down to plusnet routing or whatever ?
15-09-2016 8:07 PM
It's down to UKTV or the supplier of their software which maps the IP address to country not keeping their database up to date.
15-09-2016 10:16 PM - edited 15-09-2016 10:18 PM
There is a thread on Plusnet Feedback
IP addresses not UK - Can customers please report any problems here
19-09-2016 1:58 PM
I remember when i was in Canada and i desperately wanted to access some channels from UK but they were blocked because of the Geo-restrictions. My friend suggested me to use PureVPN there and it works for me. You can access these channels by changing your IP via PureVPN
