Wth? , suggestions?
FIXED- Subscribe to RSS Feed
- Wth? , suggestions?
09-01-2017 11:43 PM - edited 09-01-2017 11:45 PM
Hi peeps, I got 2 pics screenshot from LANScanHD App on iOS(iPad Pro running iOS 10.2).
These open port messages remain a mystery and I've had a vpn active from the second my wifi went live so it's not like it's interrupting something. Especially the message in pic#2. Anyone w answers , most grateful. No I'm not a n00b but rn I'm limited to iPad Pro rather than my laptop which I left , with all essential parts removed, when I left my last town down south. Pics enclosed, sensible answers gratefully received.|Edit|The Green tick leads to Hub manager , the Red X leads to the bizarre warning.||.Pic 1
Pic 2
Fixed! Go to the fix.
10-01-2017 7:38 AM
@crypto_sloth - I don’t think there is anything to worry about here, considering this scan was done on the LAN side. Port 139 is used for Windows host addressing, 443, 8080 and 8443 will be the alternate HTTP/HTTPS ports used for the Web UI of the router for when you have a need to use the original port yourself. Port 445 have you turned on the routers’ internal LDAP server, used to ‘advertise’ network resources to the LAN clients?
As for error in pic two, and tells me that the certificate is expecting you to use a named URL like http://local.host, or http://router or whatever was offered to you when it (the router) was configured. Have a look at the manual and it should give you the correct name. If you use that chances are the ‘error’ will go away.
Re: Wth? , suggestions?
10-01-2017 9:31 AM
139 & 445 together provide SMB shares so you'll find you probably have a share available on that machine. Presuming the device at the IP in questions is a windows box you could take a look at what is being shared using \\IP or \\IP\C$.
So long as it asks you to authenticate it's probably not an issue within a LAN but if you can access without providing credentials, you'll want to fix that.
11-01-2017 9:50 AM
11-01-2017 9:56 AM
Just got ur msg. I accidentally pressed Fixed instead of reply , *facepalm*. That's interesting, I spoke to a us guy who spent 2 yrs in prison for hacking police officers address , email (dox'd 100+ LAPD police) ; w0rmer from cabin cr3w , google him lol. Il try ur method tho thanks man 😉
11-01-2017 10:01 AM
I didn't send a message! But I do think you can undo the 'Fix' or ask a Mod to do it for you.
11-01-2017 10:07 AM
crypto_sloth
11-01-2017 10:12 AM
That was system generated when you (fat fingered) the Fixed button. When you said "just got ur msg" I thought you'd meant I'd sent you a private message, hence my "I didn't send a messsage!"
Hope that makes sense.
11-01-2017 10:20 AM
