Windows 7 - Feedback
- Re: Windows 7 - Feedback
15-01-2009 8:10 PM
15-01-2009 9:01 PM
@ Bob - you should be able to use the normal .ini files for network cards, its how I got my wireless to work, then Windows updated the drivers online
So far Vista drivers do work, so the underlying base for 7 really is Vista, only on a diet and steriods! There are a lot of drivers on Windows Update, but getting onto Windows Update without a network driver is an issue that you can only solve by going to Windows Update..... gah!
15-01-2009 9:08 PM
15-01-2009 9:45 PM
15-01-2009 11:13 PM
16-01-2009 9:35 AM
16-01-2009 7:18 PM
Quote from: Bob Managed to locate a Thomson TG123g wireless adapter so I'll give that a blast tonight...
Installed flawlessly although I did have to run it in Vista compatibility mode.
16-01-2009 11:06 PM
Wireless is onboard RaLink 2500.
17-01-2009 3:24 PM
what free firewalls have you guys managed to get working?
17-01-2009 5:47 PM
on another note, I got MSN working just fine, downloaded it, installed it and signed in. not a hitch (except tht I don't actualy use it for anything).
17-01-2009 7:01 PM
17-01-2009 9:52 PM
/edit - another bug. I did run a triple boot, Vista/2008/SuSE. Vista/08 were on my one SATA hard drive, Suse on an IDE drive. I first installed 7 on my IDE and couldn't find the option for 7 in my boot loader. Fair enough I figured, Suse can't seem to install Grub onto the proper partition either, so I just used F12 to select that hard drive at start and it worked fine. Today though I installed 7 onto my Server 08 partition, again really fast installation, its almost a pleasure. Anyhow the bootloader (Microsofts) again didn't add Windows 7 to the boot loader, Windows Server 2008 is still the boot option there which does start Windows 7. It may be because the boot loader came from Server 08, I don't know, but I've left feedback (do you think they read these things?) that the boot loader is broke. it also restarted this time after installing nvidia drivers from windows update.
18-01-2009 1:31 AM
18-01-2009 12:00 PM
If anyone can help, I would be grateful. Back on XP now ( installed 7 on a spare lappy drive I had!!)
18-01-2009 12:22 PM
my ati radeon hd 3450 graphics card got an update.
noticed that media player 12 dosent have graphic equalizer or SRS wow effect. my sub woofer isnt happy about it
