Installing WIN 7 Beta
juliasdream
Maybe I'm being dumb but I'm wontering if anyone can help or guide me to where I can find out how to do this in simple to understand steps.
I downloaded 7 Beta onto my hard drive.
Now I want to make a DVD so that I can install it on another machine
I thought I could figure out how to burn the ISO image to DVD but when I go to my DVD Burning program I get lost in the technology
I am using AShampoo Burning Studio 2009
I could install Nero if its better for the job but I dont really like nero too much
Even doing it on Nero appears complicated
Or maybe its just me running into a mental block
Re: Installing WIN 7 Beta
Both programs you load a file which is the ISO and then just burn it very simple you may have to change the default load a file ext to all files to see it
Fixes: 57
With Nero StartSmart Essentials you get this screen which answers the question
Agree with that. It's dead easy with Nero using the "Burn image" function.
I use Ashamppo Burning Suite 7.
I believe yours would be similar, this how I burn an image
Load a suitable blank DVD
Open the Ashamppo program,
from the menu select "Create / burn disc image"
then select "Burn a cd/dvd/blueray disc from a disk image"
at the next window browse to the iso image and select it, click next and Ashampoo will burn the image to disk for you.
Hope this helps, if you get stuck post back.
I don't use Nero at all, it is an insidious piece of software. I would not install it  on my machines
Jamie_Hardy
If you need something thats free and very easy to use then CD Burner XP is very good http://cdburnerxp.se/
MuppetGrinder
ImgBurn is a freeware program I use a lot.  It's nice and simple, light weight and performs well.  I recomend giving it a try.
