Windows 10 Extended Security Updates
- Re: Windows 10 Extended Security Updates
17-08-2026 6:38 PM
I signed up for Windows 10 ESU last year and everything has gone well so far but after downloading and installing this month's updates, I notice that only the Windows Malicious Software Removal Tool has appeared in Update History. I've restarted the computer but still no sign of the other two updates. Checking for Updates says "You're up to date". Anyone else here still using W10 and found this happening?
By the way, Windows 10 ESU will not end this year but will continue until 12th October 2027.
17-08-2026 7:00 PM
On my boxes, mainly AV updates:
KB Number Date Title
KB2267602 8/17/2026 6:32 PM Security Intelligence Update for Microsoft Defender Antivirus - KB2267602 (Version 1.457.211.0)
KB2267602 8/17/2026 11:55 AM Security Intelligence Update for Microsoft Defender Antivirus - KB2267602 (Version 1.457.205.0)
KB2267602 8/17/2026 10:21 AM Security Intelligence Update for Microsoft Defender Antivirus - KB2267602 (Version 1.457.205.0)
KB4052623 8/17/2026 10:21 AM Update for Microsoft Defender Antivirus antimalware platform - KB4052623 (Version 4.18.26070.9)
n/a 8/12/2026 1:00 PM Intel - Other hardware - Intel(R) Management Engine Interface Succeeded
KB890830 8/12/2026 9:18 AM Windows Malicious Software Removal Tool x64 - v5.144 (KB890830) Succeeded
17-08-2026 7:03 PM
Hi there Jonpe,
I am on the windows 10 extended support. This shows this months updates.
Hope this helps.
17-08-2026 8:23 PM
Thank you for your replies.
A few minutes ago I also noticed that the 'Feature update to Windows 10, version 22H2' had disappeared from Update History but when I checked again it was back.
All very mysterious.
18-08-2026 5:22 PM
I`ve just had a peek at mine (I`m also signed up for the extended program) and I`ve had 8 security updates this month showing under "Definition Updates". The latest being KB2267602 installed today. Have to admit it`s not something I regularly check but was prompted to do so when I saw your post Jonpe.
18-08-2026 6:27 PM
The definition updates are for Microsoft Defender. I have Norton so I don't get those updates. The ones missing from my Update History are the Quality Updates: Cumulative Updates for Windows 10 etc. and Cumulative Update for .Net Framework etc.
10-09-2026 6:30 PM
UPDATE: September's updates rather annoyingly started downloading and installing yesterday, not the 13th which is the usual date. This time they've all been added to the list of updates in Update History. What happened to the August security ones remains a mystery.
10-09-2026 7:04 PM
As I went to shut my laptop down last night I got the (Update & Shut down or Update and Restart) option. So I chose Update & Restart. Allowed it to update and then around half an hour later, closed it down. I wasn`t aware of the dates these updates are normally pushed out as I tend to just go with the flow and update when instructed!
11-09-2026 3:27 PM
@Jonpe @plusmouse The updates are available on the second Tuesday of each month (in USA). Depending on what time they are actually released, it may be Wednesday in the UK.
16-09-2026 11:58 AM
There was an OUT-OF-BAND update for W10 & 11 a day or 2 ago. An OUT-OF-BAND update is released outside the usual "patch Tuesday" (second Tuesday of the month), usually because it patches a serious or urgent issue that cannot wait until the following month's updates.
September 14, 2026—KB5129236 (OS Builds 19045.7727 and 19044.7727) Out-of-band | Microsoft Support
16-09-2026 9:59 PM
I am unsure at the moment but that OOB update may have corrected the erroneous 'notification' that Windows Defender wasn't running (i.e. I've yet to see a repeat of that 'notification')
a month ago
Every so often, I get flagged a yellow triangle notice in my "Virus & Threat" protection. I run it to update it and it just goes around in circles. It`s OK today (no action required) and usually stabalizes itself in the background So I don`t fret about it. I run Malwarebytes manually too and my machine is clean, always has been and for a 15 year old laptop....it`s still going great! However, I`ll be pitching for a newer version running Windows 11 next year.
Wouldn`t it be great if Laptops could just run the newest versions of Windows without being told your machine is past it`s best and we need you to spend £400 on an upgrade. I know about Linux as an option and Google`s options, but I`m a Windows person so I`ll reluctantly bite the bullet next year.
