While using PLEX as mediaserver, devices keep pausing
- While using PLEX as mediaserver, devices keep paus...
07-04-2014 11:45 AM
Peeps
Using Plex as a media server and now on all my devices such as PS4 and Playbook and Galaxy Note 3, when playing videos, they seem to pause intermittently and never a the same place.
before when using a sky router, this was never an issue until I joined plusnet, now it happens all the time. My poor daughter is at her wits end as she cannot watch her cartoons in peace.
Do I have to change some of the settings in the router?
cheers
Chris
cheers
Chris
4 REPLIES 4
Re: While using PLEX as mediaserver, devices keep pausing
11-04-2014 8:56 AM
Hi Chris,
I've just added Plex myself but not actually played with it too much. I've had a quick check of portforward.com which has a guide for it which is generally where I'd direct anyone with a potential port issue to as a first option.
There is a guide on there for the Technicolor router and Plex which would suggest it may not be open by default. The guide is available here: http://portforward.com/english/routers/port_forwarding/Technicolor/TG582n_Technicolor/Plex_Media_Ser...
Hopefully that'll clear up any issues, otherwise it's (most likely) going to be a job of checking the Plex FAQ/forums for further information on this one.
Dobby
Dobby
11-04-2014 9:13 AM
Hi there
You should not have to port forward for plex, for local network
Which router are you currently using
Take a gander at https://community.plus.net/forum/index.php/topic,123700.msg1074905.html#msg1074905
in the IPaddress/web/index.html#!/settings (Show Advanced settings
General =======> Support Away Mode when preventing system sleep (Vista and above) Ticked
DLNA ======> DLNA Ticked
My Plex =====> Require authentication on local networks (Ticked)
11-04-2014 9:54 AM
Thanks for the help guys
I will check when I get home and see how I get on.
11-04-2014 10:08 AM
How are you connecting to the network? Is it wired or wireless? If it's wireless, it could be that you need to change the wireless channel number due to interference from other wireless networks / video senders / baby monitors etc.
Andy
Andy
