What is connecting ?
gleneagles
Aspiring Legend
Fixes: 17
When using the internet lights flash on the router and modem as expected but there have been occasions when everything has been switched off and these lights have continued to flash at a rapid rate, also doing this even when everything has been switched off for some time.
I doubt anyone is actually hacking into my connection, more like something which I think is switched off is not, so that comes to the question, what is the easiest way to check what is currently connected using a android tablet.?
We are born into history and history is born into us.
1 REPLY 1
Browni
Aspiring Hero
Fixes: 53
Re: What is connecting ?
I use Fing on my Android mobile.
