Vista is designed to annoy
- Re: Vista is designed to annoy
14-04-2008 3:34 PM
14-04-2008 3:38 PM
...there must be something wrong with me too then!
I was a bit wary of Vista at first given all the negative press but haven't had any issues with it at all. Reminds me a bit of the "I'm sticking with Win98" arguments when Xp first came out.
BTW - This is a useful site if you want to customise Vista a bit!
14-04-2008 3:42 PM
Quote from: God There must be something wrong with me.
Bless you God, wouldn't do if we were all the same would it
My other problem with vista was that I had bought quite a high spec laptop but with Vista the performance was dull. I know there was a lot of Acer bloatware involved too. I took a drive image of the vista partition, formatted and loaded the XP to check performance.
I left it on as the laptop performed much better with out Vista and the Acer stuff..
Quote from: Paul03 Reminds me a bit of the "I'm sticking with Win98" arguments when Xp first came out.
Well I took to XP straightaway. I do intend to have another go with Vista when things are smoothed out somewhat and we have service packs that work
14-04-2008 5:32 PM
but sadly im still using bill gates lego os as i couldnt get the wpa_supplicant to work so to use wpa psk i have to use vista.
any one know an easy way to get wpa psk on any of the linux distros would have to be able to use on a usb boot as i dont want to put it on hd just yet.
14-04-2008 6:10 PM
Quote from: Santiago My other problem with vista was that I had bought quite a high spec laptop but with Vista the performance was dull. I know there was a lot of Acer bloatware involved too. I took a drive image of the vista partition, formatted and loaded the XP to check performance.
It seems that laptop vendors feel the need to ladle on as much bloatware as possible. I suspect that they are making as much profit from software bounties as they are hardware! It takes ages to trim it all off.
14-04-2008 6:15 PM
Closest I've come is with a PCLinuxOS 2008 MiniMe, in that it lets you add the packages you need, set things up the way you want them (Including, for me WPA-TKIP) THEN you can remaster to an ISO (helps to have a 1 or 2 GB empty flash drive for this).
Burn this ISO to a new CD, boot with it, it will have all your re-configured packages and setups.
Then from within PClinuxOS create a USB boot drive.
Each time I use my PCLinuxOS USB stick with my WPA connection, I just select the SSID that I need and it just connects.
14-04-2008 10:18 PM
22-04-2008 11:37 PM
http://blogs.zdnet.com/Bott/?p=429&page=1
might help you tweak vista to get what little best is to be got.
23-04-2008 8:45 AM
Turn on, get job done, turn off. I'd forgotten just how much junk there is in Vista!
23-04-2008 11:01 PM
It comes on a CD and is called "Microsoft Windows XP" LoL.
That is what I think about Vista.
24-04-2008 1:26 PM
24-04-2008 7:16 PM
24-04-2008 8:07 PM
Quote from: Be3G Windows RG would always be an alternative option.
LoL!
24-04-2008 10:52 PM
There is plenty of excellent fairly priced and free software for Vista and XP. Some of the programs I use just aren’t available on nix platforms. At the risk of being a Vista fanboi I will go on record as saying I really haven’t had a problem with Vista since day one. Open office? You can keep it, Office 2007 is better, it doesn’t ever (in my experience) crash, which Open Office does. Not all open source software is good...
25-04-2008 9:18 AM
Regards .....
