Vista & iPhone 4S problem
- Re: Vista & iPhone 4S problem
17-12-2013 4:08 PM
My daughter been using her mother's PC while her laptop is being repaired and has come across a problem when attempting to copy files from her iPhone 4S to a folder on the PC.
She gets the following error message:
The message box then closes and a new Explorer window opened.
Looking at the Event viewing for the times this has happened it says that 'File sdwinsec.exe is missing'.
A Google search has been a little confusing in that what I found indicates that it is a file used by Spy Bot S&D but is also nefarious.
MSE has been regularly updated and run on a weekly basis but CCleaner, SpyBot and Malwarebytes haven't for some time so I have asked her to run these now.
One solution being offered is to uninstall SpyBot.
Apparently the iPhone worked without issue on the laptop (W8) (MSE, CCleaner, SpyBot & MWB all installed) with same cable prior to using the PC.
Can anyone else help she some light on this, please?
Quote Windows Explorer has stopped working
plus something about looking for a solution.
Forum Moderator and Customer
2 REPLIES 2
19-12-2013 8:25 AM
Spybot has an annoying resident feature called TeaTimer. Maybe turning it off would do the trick? http://www.safer-networking.org/faq/why-does-the-teatimer-use-so-much-memory-has-such-a-high-cpu/
20-12-2013 1:43 PM
I haven't had time to check that out yet but when I suggested she use SB (among others) after cleaning her PC for her of all junk and virii some months ago I did suggest she avoid installing/activating the Tea-timer function.
