Virus software problem
Nige62
Removed Mcafee as it has packed up working properly. It could no longer connect to the Mcafee server for some reason. Also the removal tool cant be used for the same reason. Have now discovered that this problem also exists if with AVG, avast and avira, none of them can connect to server. Does any body have any idea what could be causing this?  Windows 8.1 operating system if any help.
Thanks Nigel
13 REPLIES 13
Fixes: 388
Re: Virus software problem
@Nige62 That sounds strange -especially as, as I understand it, the removal tool should not have to connect to the server to work. What AV are you currently using?
Nige62
None at the moment.
Fixes: 388
So, you are relying on the inbuilt Microsoft AV - that should be sufficient for a home-user. Are the other programs you mention still showing as installed?
Nige62
No I have removed them. No point leaving them if not working properly I thought. I tried them separately, removing one before trying another.
Fixes: 388
But you said above the removal tool can't work - 'as it can't contact the server'?
Nige62
Removed using windows uninstall. Tried to use removal tool for Mcafee as there were still files left after the initial uninstall.
Fixes: 388
OK. It is many years since I tried to remove AV programs on Windows, so can't make any further suggestions. You really need to remove any remnants, but I am not able to offer any further suggestions, sorry.
@MisterW ?
Nige62
No problem, thanks for your help.
Fixes: 585
Likewise! and Windows 8.1 Huh
Fixes: 388
I see what you mean there, @MisterW 😉 Just thought I'd ask, though.
shutter
Fixes: 67
@Nige62  A couple of good tools in the box...
1.   CCleaner... it has a uninstall window similar to WIndows   If you download it, you may get nagged to purchase it...but it reverts to the FREE version after 30 days anyway... so ignore it       https://www.ccleaner.com/ccleaner-free
2. it has a Reg Cleaner which is quite fast and quick
Another, much quicker reg cleaner is Wise Registr
Should clear out any left over scraps from previous installs/uninstalls
DS
Seasoned Champion
Fixes: 22
@Nige62 wrote: snipped
Thanks Nigel
System Requirements | McAfee in the list Windows 8.1 is mentioned when fully updated.
However I'm fairly sure that Windows 8.1 is no longer supported anymore by MS and therefore it's not being updated anymore, thus McAfee is not going to work correctly.
Maybe the other AV offerings are doing the same - IDK
shutter
Fixes: 67
copy and correction of earlier post.. (dunno what happened to it ! )
2. Another, much quicker reg cleaner is Wise Registry Cleaner
https://www.wisecleaner.com/wise-registry-cleaner.html
