Ring Doorbell 2nd Generation
Sar13
I changed my broadband provider to plusnet which was installed last week. I tried connecting my 2nd generation video Ring doorbell to new WiFi but it will NOT connect and keeps saying error. However, my Ring doorbell chime connected to new WiFi straight away???
3 REPLIES 3
DS
Seasoned Champion
Fixes: 22
Re: Ring Doorbell 2nd Generation
Welcome to the forums @Sar13
I'm assuming you're using the Plusnet Hub Two?
And if so and you're in the same room as the router, or very close to it, your phone is happily connected to the routers SSID and if you dig a little deeper you'll likely find it is on the 5GHz frequency.
Here's the kick in the teeth, you're getting wound up and you may not know but the Ring Doorbell 2nd Gen only has 2.4Ghz WiFi capabilities
So you have some options - move into another room until the phone drops over to 2.4.GHz, then connect the doorbell, or briefly turn off the 5GHz on the router - google will show you if you're not sure - then do the same.
Then after it's ding donging the doorbell with fill your phone with lovely messages showing your neighbours cats and even if your phone then reverts back to the 5GHz, you'll still get them as the bell will stay on the 2.4GHz
HTH
pyarwood
As DS says It is likely turning off 5G on the router should solve your problem.
Fixes: 480
@Sar13
If after switching off the 5GHz band it still won’t connect then on the hub advanced/wireless page try the other wireless modes.
