Vertical Line - or - "The PIPE symbol"
shutter
Fixes: 67
Re: Vertical Line - or - "The PIPE symbol"
@TheRoadCrew  A bit "iffy"  sometimes works sometimes doesn`t... qucker for me to change the Keyboard Layout".
Only use it for the odd time it is needed on Terminal stuff.
Thanks anyway Wink
