Unlocking the potential of Sagemcom 2704N
Matty123123
Re: Unlocking the potential of Sagemcom 2704N
Quote from: crazydan7
has anyone been able to change the password on this device with success?
I appeared to have the same issue at one point... I needed to restart firefox, then it accepted the new password, otherwise try "admin"
crazydan7
well i've done the same, haven't connected it to my fibre service yet, as wanted to configure it first. i'll try the password admin in the morning and see if i can get in that way, otherwhise i'm kind of stuck as since i've reset it like i said before i'm not getting in
Anotherone
Fixes: 21
Have you tried a factory reset if all else fails?
crazydan7
well the thing is, i would, but i've bent the iphone pin i used to reset last time
nickbnf
Quote from: marklkelly
Router is now in bridge mode.
For future reference, its pvc 0/38 rather than 0/35.
Thanks guys, brilliant find!
How do you change the pvc? do you need to edit the binary backup settings.conf or can you somehow change it with the gui?
Matty123123
Try http://192.168.1.254/dumpcfgdynamic.cmd . it should dump the config in text mode, then you'll see the PVC settings
nickbnf
Quote from: Matty123123
Yes, I can see <DestinationAddress>PVC: 0/38</DestinationAddress> in this xml but how can you change it? (if I used the .conf linked by Darsh to put the router in bridge mode)
Matty123123
Regarding - http://192.168.1.254/dumpcfgdynamic.cmd
You can copy & paste that config into a file E.G. "my-april-config.conf" - if you have changed the bridge mode already - that change is reflected in the most recent config that is displayed.
Then you can upload the file to http://192.168.1.254/updatesettings.html
( I hope that made sense! )
EDIT:
You could try http://192.168.1.254/modconn.cmd?action=view
but I dont know if it will allow you to edit it using the stock firmware
crazydan7
hi,
i tried admin as the password as suggested but stilll no joy
Matty123123
@crazydan7, sorry mate, your going to have to find a paperclip and press the reset button    ;(
Matty123123
Hello, I made a couple of changes to the the firmware again is anyone wants it:
https://drive.google.com/file/d/0B4-Ln6UubyEeb2l0RUFUekFFOFU/
Changed Netcat for a static Telnet  (smaller memory footprint)
Changed the PSI, so bigger configs are saved between reboots
Anotherone
Fixes: 21
Hi Darsh & Matty123123
Just to let you know, I know I'm not the only one that is appreciating your efforts and following this thread with interest - even if I haven't got to grips with (or understood Shocked ) some of it.
Keep up the good work please. Smiley
Matty123123
Hello, I thought I'll write how I opened up the router, attached is a sort-of "DIY guide" if someone would like to do it manualy.
I think I've exhausted all my knowledge now...
MS Doc format:
https://drive.google.com/file/d/0B4-Ln6UubyEeNnBiMi1pM2VZenc/
Darsh
Wow! Cleartext config! Finally! Thanks, Matt! Will dig into it now.
Your hardware breaking results are impressive! Thanks for the modified firmware, will try it soon.
Darsh
Anotherone
Fixes: 21
If any of you guys know how to get this box of tricks responding to WAN pings, a lot of people would be happy.
