Unable to get a particular web site address
- Re: Unable to get a particular web site address
27-02-2009 10:33 AM
wdbus.co.uk
I get Internet explorer can not display the web page
I used to be able to obtain it. I have a BT Voyager 2100 ADSL Router
It is not my computer or Norton as I am also unable to get to it through my Iphone when using my plus net broadband from home.
any ideas would be appreciated.
27-02-2009 10:37 AM
27-02-2009 10:38 AM
27-02-2009 10:38 AM
27-02-2009 10:39 AM
it must be something to do with my router but i do not know what
as I have just tried on Safari on my iphone and get smae result.
27-02-2009 10:47 AM
27-02-2009 10:56 AM
27-02-2009 11:47 AM
Quote from: Oldjim Works fine here as well
Jim thanks
I have tried your link and get
It's not just you! www.wdbus.co.uk/ looks down from here.
Check another site?
also a tracert shows :-
Tracing route to www.wdbus.co.uk [213.171.218.119]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms voyager.home [192.168.1.1]
2 34 ms 32 ms 35 ms lo0-plusnet.ptn-ag2.plus.net [195.166.128.53]
3 35 ms 34 ms 33 ms ge0-0-0-204.ptn-gw02.plus.net [84.92.3.93]
4 34 ms 33 ms 33 ms te2-2.pte-gw2.plus.net [212.159.1.106]
5 33 ms 33 ms 34 ms linx.bb-c.the.lon.gb.oneandone.net [195.66.224.9
8]
6 39 ms 37 ms 37 ms 88.208.255.61
7 39 ms 38 ms 38 ms pc2.prt0.fhdis.fasthosts.net.uk [88.208.255.1]
8 39 ms 38 ms 38 ms 213.171.217.3
9 39 ms 38 ms 38 ms server213-171-218-119.livedns.org.uk [213.171.21
8.119]
Trace complete.
wdbus.co.uk state their website is working and other members here can access it,
11-03-2009 3:19 PM
re set it to 1500 and now able to get the website.
16-03-2009 12:43 PM
I reported it to plusnet, they looked at it and said there was a problem with the way the sites DNS was configured.
That may be so, but why was I able to access the site from every other network other than plusnet.
