Thomson WLG-1500a driver
PeterJKing
Re: Thomson WLG-1500a driver
Thank you -- that's very kind.  Unfortunately, as other responders here preferred to respond with sarcasm and insult, and I couldn't get any sense out of Plusnet, I gave up and ordered a new adapter.
witherford
No worries glad you got the issue sorted, you might want to mark your last comment as the solution.
PeterJKing
Thanks -- I thought that I'd wait until the adapter arrives and I find out whether the problem is solved before I close the thread....
witherford
Ah ok i assumed it had arrived already, give us a shout if you need help.
PeterJKing
Many thanks.
mikelahey
Fixes: 12
In case anyone else comes across this thread. According to Wiki Devi it may be a Cameo WLG-1500 in disguise. Wiki Devi has a link to a Windows driver which should be safe to download, but I don't know whether it will work on Windows 10 or not as its quite an old chip set.
https://wikidevi.com/wiki/Thomson_WLG-1500A
https://wikidevi.com/wiki/Cameo_WLG-1500
Driver download link: http://wikidevi.com/files/Drivers/SiS/wlan_163_r105.zip
PeterJKing
Thanks -- too late for me, but I hope that it helps others.
My current position, incidentally, is that the new wireless adapter arrived, with drivers on a mini-CD; it was only at that point that I discovered that the new computer's DVD drive was faulty (I tested it on other disks too, to make sure that it wasn't the disc that was the problem).  So the computer has gone back, and I'm waiting for a replacement.
