Third party apps
gleneagles
Aspiring Legend
Fixes: 17
Third party apps
Google store has plenty of apps for android but if I understood an article in one of the computer mags it said that google were no longer supporting third party apps, exactly what are termed third party app's I am not sure but assume no further upgrades to those apps would be available ?
Can anyone enlighten me further ?
We are born into history and history is born into us.
9 REPLIES 9
DaveyH
Champion
Fixes: 12
Re: Third party apps
I think you've probably misunderstood, but difficult to say without knowing the article you're referring too.
The vast majority of apps in the play store are by third party devs, so Google are hardly going to stop supporting them.
I suspect the article was probably something to do with 'side loading' (i.e manually installing apps 'acquired' from somewhere other than the Play store)
gleneagles
Aspiring Legend
Fixes: 17
Perhaps this is what I was reading.
http://arstechnica.com/gadgets/2014/04/reminder-third-party-google-voice-apps-shut-down-in-20-days/
TORPC
The article listed was made
by Ron Amadeo - Apr 25 2014, 6:10pm GMTDT
& I can safely say that Google voice on my android still works, as I used it approx 3 - 4 days ago
Although I can not say for any of the other thousands of devices out there
gleneagles
Aspiring Legend
Fixes: 17
Can it still be updated ?
DaveyH
Champion
Fixes: 12
TORPC is comparing Apples with Oranges...
TORPC
Quote from: gleneagles
I don't know as currently there is no update showing & I can not remember when the last update was
It is running on Android 2.1 - Update1 Sony xperia  x10 mini (U20i)
@DaveyH
What make you say / think that Smiley
DaveyH
Champion
Fixes: 12
Quote from: TORPC
@DaveyH
The US version and the service they offer in the UK are rather different.
So unless you've used one of the 'workarounds' to get the US version...
TORPC
Nope as it as stock
HairyMcbiker
All Star
Fixes: 21
In this case 3rd party apps are apps that add to Google's sevices. Like gmail etc, and add an extra function that is not there as standard.
So if I have an app that lets me use gmail as a drive/file store then that is a 3rd party app, so if Google change the API's that control gmail the app is not certain to keep working unless the author updates it.
