Text from desktop computer
stathe
How do I send a  text  message fom this computer
13 REPLIES 13
PhilipHeyes
Seasoned Champion
Fixes: 28
Re: Text from desktop computer
Take a look at : https://www.mysms.com/
Fixes: 480
Moderator's note:
Thread moved from Broadband to Tech Help
pvmb
Champion
Fixes: 17
Reminds me. I used to just lurve sending people emails from my old Nokia 1100 2G phone - especially after they'd just told me: "You can't possibly email me from that thing! It doesn't even connect to the Internet."
Nokia 1100 - Wikipedia
But then, 2 weeks after the original Phone Hacking Scandal broke, the penny dropped:
"I know how they did that!"
Proving you can't beat the old advice: "RTFM!"
stathe
Unfortunately doesnt tell mer how  without paying  or joining  somethinmg must be a free way  Thanks
PhilipHeyes
Seasoned Champion
Fixes: 28
No one is going to allow their platform to send SMS for free and anonymously because it would be a scammer charter.
Why are you needing to send a text from your desktop PC
windows 10 and 11 has a Phone link app, which sends text, but you need an Android or Apple phone to link the PC to
PhilipHeyes
Seasoned Champion
Fixes: 28
There are a couple of threads on this topic and I'm now unsure if the request is how do I email from my desktop.
So that could be using an email client like MS Outlook or Thunderbird.
Or via webmail using either :
https://webmail.plus.net/
https://webmail.greenby.com
Fixes: 480
@stathe
Would I be right in guessing that you are looking to use the fault reporting bot by using your computer in place of the mobile network?
I suggest that instead you ring in and if necessary wait in the queue, should there be one.
mike600
You can Whatsapp from your PC, if that helps.
stathe
Yes I will get  someone to do that  as I have limited   ability  and  agility
stathe
I have no text message  ability to use your  fault  reports
stathe
To report my slow speed to Plusnet  phone liine  recopvered by   Openrerach at bweekendn and very slow sionce
pvmb
Champion
Fixes: 17
It used to be the case - am not up to date with this and no longer have a landline to test it - that you could indeed ask by SMS text message for a test of a given landline. If still the case then indeed somebody else could use their mobile phone to test your landline:
Text 'PHONE <landline>' to 07800 008121
Text 'HELP <landline>' to 07800 008121
For BT landline:
Text 'PHONE <landline>' to 61998
(Also worked for a Plusnet landline)
