Apps to pause WiFi on connected devices?
Portoman
I'm looking for an app to pause or stop the WiFi on devices that are connected to it. I've been told that other ISPs have apps that can be downloaded, but does Plusnet?
I did use to use Fing but you now have to pay to use the app, if you want to pause devices (I'm not paying each month for that). So are there others? Thanks
Tags (2)
7 REPLIES 7
Fixes: 387
Re: Apps to pause WiFi on connected devices?
@Portoman Plusnet do not have such an app, and I am not aware of any ISP that does. However, there is an 'access control' option on the Plusnet Hub which will do what you want - I think - but as I don't have a PN Hub, and have never used the option, I can't advise on setting it up, or its functions.
@MisterW  / @Dan_the_Van ?
PhilipHeyes
Seasoned Champion
Fixes: 24
I am going slightly mad or was there a whole lot more posts to this thread.
My comments about how VM's Connect app can Pause Wi-Fi devices on a VM Hub.
Other comments suggesting a Whitelist i.e. a permitted list of known devices (3COM had that on ADSL routers)
@PhilipHeyes
your sanity is assured, I recall commenting on this thread, my last suggestion was whitelisting
Portoman
Which is good if you've got VM I guess!
mwwagain
Fixes: 4
The 'app' required is surely just a basic web broswer to access the router control page ?
Then turn the wi-fi off.
Turning it back on remotely will be more tricky - you'd need a wired connection !!
PhilipHeyes
Seasoned Champion
Fixes: 24
@Portoman
The VM Conenct app just adds or deletes a record to the MAC Filter of the VM Hub.
A job  that can be done just as quickly from the Hub / Router menu of any make of device.
The killer issue is not the app or menu to the MAC Filter, the fact that modern laptops / PC and mobile
all have MAC Address Randomisation often enabled from the factory and can defeat MAC Filtering.
Hence the next step ... a Whitelist and do know exactly what you are doing if you enable that !
RealAleMadrid
Fixes: 68
@PhilipHeyes  I believe there were some suspicious spam type posts with dodgy links in them that have been removed, and probably other replies have also gone.
