Switching to EE
smeech
Re: Switching to EE
After a weekend of silence we have solved the problem:
  • "[email protected]" (replacing "username" with my ID, of course) for my SMTP User Name: and my email From: address (rather than "[email protected],com") worked
  • I'm now using "mail.enmail.co" as my SMTP server, Port: 465, Authentication method: Normal password, Connection security: SSL/TLS
  • The problem was my use of aliases to send email. I have never used the "[email protected]" format. Greenby have kindly added my most frequently uses two aliases in the Email, All Mailboxes settings.
sstoddart
Re: Switching to EE
Greetings @smeech
Thanks for the heads-up...
I don't use an alias so I should see the same problem.. the change in mail server is good to know though 🙂
Cheers
Steve
smeech
Re: Switching to EE
I have several: for email that relates to me, my youngest son, my wife, my mother, a spam-trap, and a voluntary role. Now I know how to reestablish them I should be OK, especially as I only need to do that for outgoing mail. Most of my email is filtered into folders by Thunderbird, and aliases make that much simpler.
